Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-09-2004, 11:51 AM
SBV45's Avatar
SBV45 is starting off with a positive reputation.
More about oil
OK, I'll probably stir it up again, but.... I changed my oil. I was running Castrol HDL Tection 15-40. I changed to Delo 400 15-40. After starting when the engine was cold, I was amazed at how much louder it was with the Delo. I drained my crancase (love that Fumoto valve) and filled with Castrol again. I started it the next morning it was much quieter. I checked the Delo containers to make sure I had put the right weight/type oil. I didn't think there would be that much difference between oils of the same weight. It has been 60 here in the mornings and I park in the garage anyway.
Anybody with similar experience between oils?
__________________
03 F250SD 4X4 6.0L PSD 5speed auto. 3.73 diff, extended cab, Raven shell. 4/2/03 build, 3/27/03 engine build.
  #2 (permalink)
Old 04-10-2004, 07:42 AM
IB Tim's Avatar
Administrator
IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation
There was no doubt in my mind, that noise is significantly reduced after I went to syn.
__________________
Administrator
tim.lamkin@internetbrands dot com
Life is not only time……paradoxically, it is the denial of time!
What lies behind us and what lies before us are tiny matters compared to what lies within us.
  #3 (permalink)
Old 04-10-2004, 10:16 PM
Choctaw Bob's Avatar
Choctaw Bob is starting off with a positive reputation.
Noise is down to next to nothing when warm with Mobil Delvac 1
__________________
03 6.0 SC Short bed 2WD Auto
Preditor, Gages, K & N FIPK
  #4 (permalink)
Old 04-10-2004, 10:55 PM
dbm04F250 is starting off with a positive reputation.
My first oil change @ 5,000, I tried Rotella and although I didn't really notice any difference in the truck running ... I did have a significant decrease in mpg. I think I will try Delvac 1 as originally planned on this next change and see what happens.
__________________
2004 F250 CC Lariet SB 6.0 PSD FX4 Torqshift, 09/30/03 Engine Build, 10/03/03 Build Date.
  #5 (permalink)
Old 04-11-2004, 09:59 AM
IB Tim's Avatar
Administrator
Quote:
I did have a significant decrease in mpg…….OK I am having a hard time finding the correlation between the oil change and the loss in MPG Did anything else happen, like cold weather or…operative word here is “significant”
__________________
Administrator
  #6 (permalink)
Old 04-11-2004, 10:04 AM
SBV45's Avatar
What is a significant decrease in mpg? I don't understand why an oil change would affect mileage.
__________________
  #7 (permalink)
Old 04-11-2004, 10:15 AM
Quote:
Heavier oil takes more power to pump. This truck has two pumps, a high pressure pump (4000 psi)runs the injectors. This is a lot of the mechanical noise under the hood. This pump takes a lot of power. The low pressure pump lubricates the engine. There is also parasitic drag, the crankshaft turning through the oil at the bottom of the block that hasn't made it to the pan. This is why it is important to not overfill the engine oil.
These actually do affect mileage. This and excessive oil pressure with heaver oil is the reason so many dealers are wanting to recommend a 5W30 oil to 6.0 owners.
__________________
  #8 (permalink)
Old 04-11-2004, 11:25 PM
All I can say is that after my first extended trip, holiday weekend from S. Ga. to Atlanta and back (with good trip mileage). I changed the oil the following weekend at 5,000 miles. The next tank of fuel showed a decrease of almost 3 mpg and has sustained that since then with a slight improvement with the weekly routine being the same as before the trip and oil change.
__________________
  #9 (permalink)
Old 04-11-2004, 11:29 PM
IB Tim's Avatar
Administrator
OK, this has to be one for the record, I have never read of this resuilt before.
Same fill up palce also?
__________________
Administrator
  #10 (permalink)
Old 04-24-2004, 12:33 PM
matt1751 is starting off with a positive reputation.
I had my first oil change done by the dealer at 3000 miles on my 04 F250 PSD, Since then I have noticed a lower Idle at cold start, decreased MPG by about 2MPG and intermidiate lack of power which seems to vary depending on outside temp. I was wondering should I go back to the 10w30 that was in the engine for the break in period as the truck ran great or should I try a syntheic like the Mobile Delvac 1 5w40, I'd hate to waste $$ on oil trying different weights. The other thing I was wondering is I've been seeing prople on here say they only put in 13-14qt's but the manual states 15qt including filter but yet my invoice from the dealer shows 16qt's, I checked the level and is slightly above the Full indication on the dip stick(gray one). did they over fill causing these problems? Should I drain some oil out? This is my first PSD and been learning new things about them daily, I love the truck and this site, Any suggestions would be appriciated,, thanks matt
  #11 (permalink)
Old 04-24-2004, 12:59 PM
Beachbumcook's Avatar
Got Diesel?
Beachbumcook has a good reputation on FTE. Beachbumcook has a good reputation on FTE. Beachbumcook has a good reputation on FTE.
Go back to dealer and show them the book (15 qts).
Show them the "high level" on the tip stick and force them to drain out the excess and refund you for 1 quart of oil.
System hold just over 15, but you can only "drain" 15 (extra quart (or less) is inside high-pressure system.
They over-charged you and over-filled your truck - Keep all paperwork and receipts so if you have any problems, you have proof that they OVERFILLED!!!
Good luck and let us know how it pans out.
Jeff
__________________
03 Excursion 6.0L PSD
Magnafine P/S Fluid Filter
Racor By-Pass Oil Filter System
Dieselsite Coolant Filter
Bilstein Shocks/Rancho Steering Stabilizer
Fumoto Oil Drain Valve
BriteBox Headlight Module
Marinco AC Block Heater Plug
24" Wiper Blades
Window Screen - Radiator Bug Shield
Pioneer Airware XM Radio
  #12 (permalink)
Old 04-24-2004, 01:57 PM
Quote:
We all are learning our terriffic but complicated and different trucks.
My oil change to 15W40 Motorcraft brought a 1 mpg drop of mileage. I picked up two to 17 with another quick change to Mobil D 1.
I have had mileage jump around the last few weeks. It is probably related to the winter/summer fuel changover. My truck will only hold 14 Qt. I think I will drain to 13.5.
You may have 16 because the size of the pan a quart doesn't raise the level very far.
__________________
  #13 (permalink)
Old 04-25-2004, 12:17 AM
Yes Tim, Fill ups were from the same place. Twiddle your thumbs, tap your feet slow top offs and documented the same as I had been doing. See my thread in 13.5 Quarts in 6.0L as well for and explanation on the amount of oil required @ oil changes vs the 15 quarts that the manual states. Basically 15 quarts would be required for a completely purged system which does not take place during normal oil changes. Hence the need to watch the dip stick when you get to the last couple of quarts. You are only replacing what you have removed.
__________________
  #14 (permalink)
Old 04-25-2004, 12:26 AM
johnsdiesel's Avatar
johnsdiesel is starting off with a positive reputation.
dbm, a completely purged system would require 15.95 quarts. The 15 quarts is the refill capacity. This was the same thing they did with the 7.3, listing the refill capacity knowing you wouldn't be able to drain the HP oil reservoir. If you're not getting 15 quarts of oil out of the system I would suggest calling Ford.
__________________
1997 F250 HD PSD SuperCab 4X4 ZF5 4.10
173K miles
CMP Info1
CMP Info2
  #15 (permalink)
Old 04-25-2004, 12:43 AM
Quote:
The manual may say 15 but 14 fills mine slightly over the full mark on the dipstick. Have you changed the oil on your 6.0 yourself? All of us that have seem to agree on 13.5 to 14 quarts.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
