My 1996 Ford Ranger XLT has been blowing cold air while idling for the last few weeks. Today on the way to work the heater was even blowing cold air while I was driving and I thought that it was going to overheat when I was stopped. Luckily the heat kicked on halfway into the ride and I was able to make it to work. What is the most likely problem and is it probably a few hundred dollar fix or are we talking a thousand and up. The vehicle has over 160,000 miles on it and I don't want to put a lot of money into it.
\Very possibly low coolant due to a leak. If it has one of those plastic water valves for the heater check it for leaking at the shaft... very common leak source on the Ranger/Explorer.
__________________
My advice is just advice..Its free "IF THAT DONT FIX IT, SOMETHING ELSE WILL"
