2.3L Knocking problems
Old 04-18-2004, 07:42 PM
fmarino's Avatar
fmarino
fmarino is offline
Exclamation 2.3L Knocking problems
Hi there, I replaced the timing belt on my 94 ranger today. When I removed the old one, I noticed that it was a tooth off! I had been driving the truck like that since I bought it last Fall. In any case, I installed the new one correctly (lining the timing marks) The problem I now have is that the engine is knocking even on low gears when I push the gas. I read about carbon deposits, is that a possibility? I have changed the plugs and the O2 sensor. Thanks for any help
P.S. I noticed that the base timing is OK at 10 BTC, but as soon as I plug the SPOUT, the timing jumps to 20 BTC and when I rev it up it goes past the scale to about 40 + BTC, is that normal? Please help!
Old 04-29-2004, 08:46 PM
smittyranger1993's Avatar
smittyranger1993
smittyranger1993 is offline
umm yea u might wanna check the oil. my old truck did that and i ended up throwing a rod right threw the block.
