Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Western Region > Colorado Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Colorado Chapter Join Chapter, Leader: RIKIL
  #1 (permalink)
Old 04-07-2004, 01:02 PM
CKaye CKaye is offline
Garage is empty, add now
CKaye is starting off with a positive reputation.
Spray in bedliner?
It's apparent in all of the spray on bedliner threads that application may be the most important step in whether or not it'll hold up.
So, I'd love to hear from those of you who have gotten a spray in liner. What brand did you get, who did it for you, and are you happy with it?
Thanks!
  #2 (permalink)
Old 04-08-2004, 08:12 AM
slowsix slowsix is offline
slowsix is starting off with a positive reputation.
Rhino Liner about 3 years ago. A little shop at Bellview and Windemere. I would get a spray in liner again but I would probably go with a Linex. They seem to look better over time.
  #3 (permalink)
Old 04-17-2004, 08:58 PM
mattadams mattadams is offline
mattadams is starting off with a positive reputation.
I have a good story for you, and a bad story for you.
When I bought my truck, it had a recently sprayed rhino liner in it. while I didn't like the fact that they sprayed over the bolts, figured oh well, not much I can do about it, its still a good liner. About 3-6 months after that (figure the liner is now 6-9 months old) the liner began fading horribly, and even peeling in some spots. The liner is basically brown, not black, not good looking at all. In addition to that, since they sprayed over the bolts its made it impossible to do a body lift or body work without adding countless hours to the labor of it. Whenever I went to Rhino Lining to see what they could do, I was told they could do nothing, the lifetime warranty didn't apply to me because I was not the original purchaser of the vehicle. I used every product they recommended, and it'd make it black again for a day or two, then fade right back to the drab brown that it is now. I will neve rhave another rhino liner installed again.
Now, on to Line-X. I have it installed on my roll bar, my nerf bars, my taillight covers, and my brushguard. I love it. I've had it on there for about 2 years now and it hasnt faded at all. It's held up to all kinds of abuse and works great. The Line-X dealer on santa fe near C-470 even told me if I could rip out the rhino lining, he'd do the bed for half price because he saw what horrible condition it was in. Unfortunately I can't afford even half price right now, nor do i want ot take the rollbar/toolbox out again (its a massive ordeal, trust me!). But he's sprayed my other stuff and I've been very pleased with the results. Highly recommend it.
FYI, the Rhino shop on belleview and windermere is staff with a bunch of guys that speak about 10 words of english, very frustrating when trying to tell them the problem with my liner.
  #4 (permalink)
Old 05-10-2004, 09:37 PM
r1cgriffin r1cgriffin is offline
r1cgriffin is starting off with a positive reputation.
I had a Rhino liner on my 2001 F-250. It held up great it never faded even with all the gas and diesel i,ve spilt on it over the years. I had it installed in Colo Springs at chelton loop(?) . I have since gotten a 2003 F-250 at about ten months I had it sprayed by Rhino also and it is a good job also. The workers will answer all questions.
I looked at some other brand but did not like how thin most of them were. Rhino told me if I didn't want the bolts covered they could be removed before spraying.
  #5 (permalink)
Old 05-11-2004, 08:30 AM
TRNITUP TRNITUP is offline
TRNITUP is starting off with a positive reputation.
If you don't mind me asking, what did you guys pay for your liners?
I'm really needing to get mine done, as I have quite a few areas scratched and banged up, and I really don't want the rust to start. But, I'm a cheapskate, so I have to be on the lookout for money savings.
  #6 (permalink)
Old 05-11-2004, 09:54 PM
Talking
Rhino lining just went up end of March I payed $422.00 in April for black- I was told custom colors cost an extra $80.00. This was in Colorado Springs.
  #7 (permalink)
Old 06-01-2004, 01:46 PM
zamboni250 zamboni250 is offline
zamboni250 is starting off with a positive reputation.
I have a LineX. Had it done about 6 years ago. Still holding up really well, looks great too! Im not sure what I paid but im sure it has gone up since then anyway. Good Luck
__________________
2004 F150 XLT. 2004 Explorer XLT.
  #8 (permalink)
Old 06-03-2004, 08:25 AM
TruckDaddy TruckDaddy is offline
TruckDaddy is starting off with a positive reputation.
LINE-X contains polyurea, Rhino does not. Here are the advantages of polyurea:
1. Higher temperature tolerance, LINE-X is 350 degrees, Rhino is 175 degrees. As the temp of the bed approaches the temp tolerance (in the summer), the liner begins to lose its strength.
2. Polyurea is more chemical resistant, especially with organic oils and solvents.
3. Polyurea makes the liner harder. LINE-X's tear strength is 304 lbs., Rhino is 145 lbs.
4. Polyurea produces a more dense liner by keeping moisture out of the mix during the application process.
5. Less moisture in the mix also means better adhesion to the metal.
6. Polyurea makes the liner dry fast, 4 seconds average. So, you get a very even application throughout. Rhino takes a minute or two to even gel, so gravity pulls the liner from the high ridges into the low valleys.
Since Polyura sets up very fast, LINE-X uses a high heat/high pressure application. This produces a much nicer finish. Rhino uses a cold/low pressure system which makes it look sort of gouped on. To be fair, Rhino is in the process of changing to a high heat/high pressure system (because it looks more like LINE-X), but the product still does not contain polyurea.
  #9 (permalink)
Old 06-09-2004, 08:37 AM
by the way, anyone interested in Line-X, you can get a discount at the line-x dealer on santa fe in littleton. Just say you are with the Rocky Mountain Ford Truck Club
  #10 (permalink)
Old 07-09-2004, 11:03 AM
XdieselX XdieselX is offline
XdieselX is starting off with a positive reputation.
I just got my bed done with line X yesterday and I love it I paid $445 here in chicago. I did alot of research on best bed liners and came to the conclusion that line X is the best and has the best warranty. good luck.
  #11 (permalink)
Old 08-30-2004, 01:36 PM
myf250's Avatar
myf250 myf250 is offline
myf250 is starting off with a positive reputation.
Custom Linings
I just got my truck done with Custom Linings. I think they are kind of new. I am very satisfied with it so far. It was about 150.00 cheaper than Line X. I got it done at Timberland Toppers in Colorado Springs. I paid 295.00 for my F250 short bed. They use the same materials as Line X and applied the same way. Same warranty as well. Hope this helps
  #12 (permalink)
Old 08-31-2004, 09:35 AM
Shortbedman68 Shortbedman68 is offline
Shortbedman68 is starting off with a positive reputation.
We once sprayed Rhino liner on my cousin George just to see what would happen to him. Let me just say this ain't a good idea.
  #13 (permalink)
Old 09-01-2004, 09:21 AM
Mike G Mike G is offline
Mike G is starting off with a positive reputation.
I'm sorry, I just cant stop
--Mike
__________________
Mike G
The Ford related items representing 1/3 of what's in the garage....
1965 F100 LWB 401FE power and C6
1968 Cougar XR7 (wife's toy)
2001 F350 Long-Crew-Dual-4x4-7.3L TD Hoss
  #14 (permalink)
Old 09-01-2004, 09:58 PM
grock grock is offline
grock is starting off with a positive reputation.
Hi,
Has anyone tried the Reflex spray-in liner? It has a rubbery feel that makes me think it woudl be less slippery than the harder spray-in liners.
Thanks.
  #15 (permalink)
Old 10-15-2004, 09:30 AM
ceetwarrior's Avatar
ceetwarrior ceetwarrior is offline
1967 Ford F-100
ceetwarrior is starting off with a positive reputation.
I just got my truck done here in Colorado Springs. $412. The rhino line shops on Chelton Loop. Same place r1 was saying. They did a very good job. I have a friend who got line x and he said it chips compared to rhino line, where rhino stays flexable. Flexable is good. If you go to the rhino dealer (the only one in COS is on chelton loop) they sell rhino renew which is what your supposed to use to keep it looking new. I called timberline toppers like myf250 did, their bedliner is only 1/8" thick and it was $375. I was like, dang, I can get 1/4" rubberized rhino liner for $400.
They will take out the bed bolts for ya but it'll cost more. Besides that, if you don't rhino over them then they can rust out because their not sealed. That's another plus for rhino is the rust prevention.
__________________
-There's no replacement for Displacement
My Gallery
Tags
bed, bedliner, bedliners, colorado, cost, line, liner, liners, linings, reflex, rhino, richmond, spray, springs, truck, va
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
