96 psd won't start every time
I own a 96 F-250, 7.3 psd and have a no start problem. Let's say I use the truck in the morning for a drive to the store, it will start and run fine. Now, get back into truck and try to go home, if it will start it runs fine, but if it don't want to, I can wait awhile (maybe 20 min, or so) and the motor will run. I was told that a bad fuel pump was the culpret, wrong still does it. Then I rebuilt the fuel filter assy, (had some air in return), and replaced all the rubber fuel lines, but the problem still exists. What about the cam position sensor, how do I test it.
Quess what, I went to goggle and typed in ford camshaft position sensor. A link popped up to troubleshoot sensor and wiring http://www.ford-trucks.com/faq/9497f.../ecsd/cmp.php3
