Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Engine Swaps
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-06-2004, 10:50 PM
IAM.CA is starting off with a positive reputation.
351M to 460 Oil Pan
Did a search, must have been using bad search words, so I never found a good answer. I'm swapping a 460 into a 78 F150 4x4. I know I need a rear sump, but one of the only pans I could find was $300 and chrome. I'd prefer to get something cheaper, OE style that I can just get ordered in from a parts store, not from L&l. I heard econolines or 83+ trucks have the right oil pan. None of the parts shop could positively ID it as a rear sump for me.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-07-2004, 12:16 PM
terryr is starting off with a positive reputation.
Check the wreckers. They should let you look some over and return it if it doesn't fit. Even if you don't buy used you can see which truck has the right one.
__________________
Bits of Tech
  #3 (permalink)
Old 04-12-2004, 11:37 PM
Thrillseeker is starting off with a positive reputation.
If you still want to put the 460 into the F150 4X4 get yourself a pan from a '79 van that had a 460.. I don't remember the part # but I bought a new one when I put a 460 into a '79 Bronco.. You can get monts from L&L or if you take your time you can make your own from like I did from the flat 390 motor mount and a 3/8" plate.. When I got through the 460 sat in the same holes the the 351M did.. . I do remember it took me 5 days to come with the home made mount, but the engine sat level and the installation looked good.. Good Luck
  #4 (permalink)
Old 04-13-2004, 10:23 PM
Thanks, I'll go and check out a the van pan.
  #5 (permalink)
Old 04-15-2004, 03:42 AM
Superdave is starting off with a positive reputation.
Quote:
Fordmotorsports has a rear sump pan, dip stick and tube, long oil pump pick up tube, and the main bearing cap bolt with the stud on the end of it to support the longer pick up available together as a kit for $160.-$180. depending on where you buy from. Jegs sells these in their Mustang section.
I used one with my 460 swap in my 82 F-250 4x4. It is an OEM replacement also.
If you go the van route which will work, be sure to grab the exhaust manifolds too. These will fit between the frame rails fine.
__________________
Superdave
95 Ford F-150 4x4, XLT, 5.0L, A/T
82 Ford F-250 4X4, XLT, swapped 468 CID, C-6 A/T-B&M Shift kit, 8700lb GVWR, Black & Silver
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
