Powerstroke has no power when cold - Ford Truck Enthusiasts Forums
Old 12-31-2002, 01:01 PM
jschira's Avatar
jschira jschira is offline
jschira is gaining momentum as a positive member of FTE.
Old 01-02-2003, 12:47 AM
corkybarder corkybarder is offline
corkybarder is starting off with a positive reputation.
'97 F350 Powerstroke w/auto. When starting truck when cold, the truck fires up just fine. But when you drive, there is no power and a ton of black smoke pours out. As soon as the temp gauge hits the 'r' in 'normal', it's like someone threw a switch and the truck runs fine. If you plug the truck in the night before, I don't have the problem, it starts and runs right away. Any ideas?
Old 01-02-2003, 01:16 AM
Ghostrider304 Ghostrider304 is offline
Ghostrider304 is starting off with a positive reputation.
Diesel engines get all there power when they are hot. A cold engine can't burn the fuel because it take pressure and heat to combust the fuel. Thats why you get black smoke, all of the fuel is not burning. Best bet if you don't plug in the heater over night, is to start it up about 5 to 10 min. before leveing and it will have time to get up to operating temp and give you full power quicker.
Hope this helps!
Will-
Old 01-02-2003, 08:06 AM
alanscott's Avatar
alanscott alanscott is offline
alanscott is starting off with a positive reputation.
That sounds like your exhaust back pressure valve is kicking in. Here is another thread on it.
http://www.ford-trucks.com/dcforum/DCForumID101/2169.html
Next time you fire it up cold, listen to the exhaust and see if it has a high pitched tone to it. Mine seems to kick in when it's around 17 degrees or lower.
Old 01-02-2003, 08:53 AM
johnsdiesel's Avatar
johnsdiesel johnsdiesel is offline
johnsdiesel is starting off with a positive reputation.
I don't know about the black smoke, but when the engine is cold the exhaust back pressure valve is activated to help warm up the engine. You should never really work the engine when it is cold anyway. As far as the black smoke, check your air filter.
Old 01-02-2003, 11:48 AM
Sun Sun is offline
Sun is starting off with a positive reputation.
Do you have an oil consuption problem?
The symptoms you described are classic of bad injector seals. My mechanic went over this problem w/ me just the other day. He actually said "is it down on power, especially when it is cold?". He then went on to state that would mean the that there is an injector seal problem.
Old 01-02-2003, 01:43 PM
There is not really a oil consumption problem...it uses about a quart between changes. After the temp guage comes up, the truck runs fine but until then, just no power, and if you step on the gas, black smoke comes out. The fastes the truck will go until it warms up is about 30 mph. I have not noticed a whistle in the exhaust during this, but I will kill the butterfly when I get home and see if this works for in the morning.
Thanks for all yall's help!!
wheels 1973 - 1979 F-100 & Larger F-Series Trucks 7 04-13-2004 01:08 AM
is this common 1987 - 1996 F150 & Larger F-Series Trucks 3 11-12-2002 02:38 AM
Wheelbase 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 01-14-2002 10:06 AM
Overheating 1973 - 1979 F-100 & Larger F-Series Trucks 8 03-11-2001 11:13 PM
Tags
02, 2000, 97, cold, ford, power, powerstroke
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
