Ultra quiet Steel???
Ok, even those that have the various vibration problems say this new F150 is a ride worth fighting for. I wish them the best and I hope they can get together via e-mail to colletively solve the problem. But the question is can this ride be made even better? Here were some ideas I came up with thanks to this great forum I enjoy:
1. Floor Mats. installing top quality floor mats will help dampen road noise. I would recommend either Nifty Catch all or the Husky which ever is the thickest and give most coverage. I'd also add some layer of cover under the seats. I'll do more research to find out which brand is the best.
2. Undercoating. I've read an undercoating such as Dynaliner Max, Cascade VB 4, and Quiet Kote can dampen road noise.
3. Spray on bedliner. Spray on is better than drop in since drop in rattles. It provides more dampening properties added to those I've already listed. The best ones are Rhino, LineX, and Speedliner. The one that is the thickest would probably be the best pick. Rhino seems more "rubbery" thus may be the best pick.
4. Daystar Comfort lifts. Even though I only have a 4x2 these can still be installed I've read that these also help with the quality of the ride.
5. ??? Any other suggestions can be added here!!!
Not to change the subject, but on the topic of "Quiet Steel" I thought I'd mention this.
I read in the newspaper that the 5.4L 3V oil pan is also made out of Quiet Steel to keep engine noise down.
This may persuade you to get the optional skid plates on Lariat 4X4 to protect that oil pan because It's probably EXPENSIVE.
on mine i went to a car stero store and bought some sound deading pads, peeled the carpet up put them on the floor boards and firewall, also added insulation around floor where your feet are, helps keep your feet warm when its really cold out on long trips. also added insulation the roof inbetween the head liner.
any one got a suggestion for wind noise around the windshield area? It may just be me but I think my truck has excesive wind noise coming from the lower windshield area. I thought it was the large mirrors, but the more I listen it's coming from the windshield. I drove my dad's 97 f150 the other day and it really had wind noise around the mirrors, but the windshield area was dead quiet.
when you open the drivers side door it you should see a sticker on the inside of the door somewhere depending on your cab configuration. It will have your build date, to my knowledge anything built feburary or after is job#2. Also you can look at your window sticker and it should say somewhere either job#1 or #2.
The reason I keep harking about this is I specifically remember test driving 3 different FX4 trucks from late December through early January which were all job1 trucks. On the interstate at 70+ mph I promise I didn't hear anything (except the rear window rattle). If I searched back on the forum enough I could find my posts describing my first test drive. It was best described as watching a Nascar race with your TV on mute. I thought the truck was dangerously quiet. But my truck isn't this quiet, its almost like they forgot to put a seal around the lower portion of my windshield, it sounds like I'm always driving into a constant head wind above 50mph. My service tech ran my VIN for a possibe TSB but it didn't have anything.
Hopefully I can find a less expensive material.
