What is difference between turbo and powerstroke - Ford Truck Enthusiasts Forums
Old 01-03-2003, 07:38 AM
BlacKMaGic BlacKMaGic is offline
BlacKMaGic is starting off with a positive reputation.
just curious, cuz i've seen that they have 3 different diesels listed for 94 a regular, a turbo, and powerstroke. the one i just purhcased is a turbo diesel. what are advantages or disadvantages. can i upgrade this to powerstroke levels?
Old 01-03-2003, 08:12 AM
bilder12 bilder12 is offline
bilder12 is starting off with a positive reputation.
the difference in the diesel engines is
7.3 naturally aspirated (non turbo)
7.3 turbo diesel, which has a turbocharger to force more air into the combustion chambers, making more power in the same size engine. The 7.3 turbo diesel uses an injection pump that is engine driven and mounted on the front of the engine just over the valley pan. You will see 8 fuel lines connecting the pump to the injection nozzles of each cylinder. (Over the road diesels have used this engineering for a long time). This also allows the fuel to be burned more efficiently.
Power Stroke - is basically the same block, except now the fuel is controlled by electronic controll. The fuel pressures have also been increased to allow for a better fuel burn (required by government regulations).
You cannot change the 7.3 turbo diesel engine into a power stroke engine, but you can change the 7.3 naturally aspirated engine into a turbo diesel.
hope this helps a little
Old 01-03-2003, 04:23 PM
welderford390's Avatar
welderford390 welderford390 is offline
welderford390 is starting off with a positive reputation.
7.3 Liter IDI - Indirect Injection (Basically easier to work on than the powerstroke)
7.3 Liter PSD - Direct Injection
1969 Ford F-250 4X4, 390 bored .030 over, carter 4 barrel carb, Terminator mufflers, NP 435, NP 205 Transfer case, HD Dana 44 w/ discs up front and Dana 60 in the rear. 90% completly rebuilt from ground up.
1995 Ford F-250 4X4, Powerstroke Diesel. Supercab longbox. 70 hp chip, Tymar Air intake, isspro pyrometer and boost guages. Other than that its stock. Plans: 4in exhaust, propane injection, cd player, and possible intercooler.
Old 01-03-2003, 09:57 PM
The Diesel Dude The Diesel Dude is offline
The Diesel Dude is starting off with a positive reputation.
The Power Stroke does NOT have basicly the same block as the IDI engine. There are 2 different engine families: The indirect injection (IDI) engine and the Power Stroke which is a direct injection engine. For 93 and 94 there were 2 IDI engines, a naturally asperated and a turbo charged version. The IDI engines inject their fuel into a precombustion chamber. These engines will be painted gray. For 94 there were 3 engines available, the 2 aforementioned IDI engines and the Power Stroke. The Power Stroke injects its fuel directly into the cylinder. These engines will be painted black.
Old 01-04-2003, 01:28 PM
excuse me. I stand corrected. I was of the impression the power stroke was a 7.3 displacement engine and I thot the differences came from the head designs. I would appreciate learning the differnces if someone would explain them to me.
Old 01-04-2003, 02:09 PM
The 6.9/7.3L IDI engine was a gasoline engine conversion from the International Harvester 404/446 MV8 engine. Because it was a gasoline conversion, there was a constant problem with getting the casting clean inside the water jackets (bore spacing was too close). The 7.3L Power Stroke/T444E engines were started from a clean sheet of paper. The only parts interchangable between the 2 engine families are the roller hydraulic lifters. Interestingly enough, the only parts interchangable between those engines and the new 6.0L engine are the roller hydraulic lifters.
Old 01-05-2003, 08:00 AM
jschira's Avatar
jschira jschira is offline
jschira is gaining momentum as a positive member of FTE.
Old 09-21-2003, 12:54 AM
89ford73's Avatar
89ford73 89ford73 is offline
89ford73 is starting off with a positive reputation.
i have an old ford 7.3 n/a and i was thinking about port and polishing my heads and finding an old powerstroke and robbing the turbo, lower compression pistons, cam, and crank because i heard the rod journals were different but the mains were the same i know banks makes a sidewinder bolt on turbo for like 110 hp and 130 ft lbs but i was thinking more like 700+ hp and 1000+ ft lbs torque. will any of this stuff fit?... do you know where i can find this kind of stuff that will fit? i know alot more about diesels than your average joe, im thinking about going to truck pull contest and showing all those cummins havin fools how to drag a sled the ford way
Old 09-22-2003, 01:21 PM
HrlyDr's Avatar
HrlyDr HrlyDr is offline
HrlyDr is starting off with a positive reputation.
Quote:
Originally posted by 89ford73
ii know alot more about diesels than your average joe, im thinking about going to truck pull contest and showing all those cummins havin fools how to drag a sled the ford way
If you know so much about diesels, why do you hafta ask what fits?
1,000 ft/lbs...now THAT's some torque!
Old 09-23-2003, 09:08 PM
1970 F-250 1970 F-250 is offline
1970 F-250 is starting off with a positive reputation.
The 7.3, 7.3 Turbo diesel, and the 7.3 powerstroke all have the same displacement, which is like 445 cubic inches. The 7.3 factory turbo diesel has 20 more horse power than the standard 7.3. The 7.3 and 7.3 turbo are both IDI(has glow plugs) and have precombustion chambers. The powerstroke is DI(no glow plugs) and sprays a fine mist into the top of the piston. It is also computer controlled. The 7.3 powerstroke has like at least 40 or 60 more horsepower than the 7.3. The powerstrokes are very efficient, for how much power they put out. They make about 16-18 mpg. I have a 1994, F-350, 4x4, 5spd. factory turbo diesel. It gets 18mpg unloaded. It is less complicated than the computerized powerstroke, but its a pain in the winter, without DI, like the powerstroke. I like my 7.3 over the power stroke, because I can at least fix it my self(since I am a diesel technician), because it isn't computerized like the powerstroke.
Old 09-25-2003, 12:15 PM
Blaine Schulte Blaine Schulte is offline
Blaine Schulte is starting off with a positive reputation.
powerstroke have glow plugs under the valve covers. since your a diesel tech. here's a question for you. i have posted a thread about not being able to keep the oil filter gasket from blowing out on a freshly rebuilt engine. search my name and see the thread. waiting to her your input diesel tech. i am a diesel mechanic!
Old 09-25-2003, 08:51 PM
RawPower's Avatar
RawPower RawPower is offline
RawPower has a very good reputation on FTE.RawPower has a very good reputation on FTE.RawPower has a very good reputation on FTE.RawPower has a very good reputation on FTE.
THEY ARENT THE SAME ENGINES. I hope you don't think this, but you did make it sound like it. The IDI has NO computer controling the engine, while the Powerstroke does. If you were to do a swap, you would need the computer out of the powerstroke. (To make it more clear, you would be removing the whole engine in your current truck and some of its components, then replacing them with a new engine and new components, not only under teh hood, but its recomended that you get at least a 3" exhuast, as the powerstroke does, and a thicker, stronger driveshaft). The Powerstroke is more powerful, horsepower and torque, but harder to upgrade or work on. You cannot put those performance ships in the IDI's since there is no computer.
Old 04-03-2006, 02:03 PM
efoster_01's Avatar
efoster_01 efoster_01 is offline
efoster_01 is starting off with a positive reputation.
will they both bolt up to the same transmision? a 1990 7.3 IDI and a 2003 7.3 powerstroke.
Thanks,
Bone
Old 04-03-2006, 06:28 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
Dave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to behold
Yes they will.
You can bolt the six speed transmission out of a 2002 7.3 Power Stroke to a 83 6.9 if you want to.
But then this post is almost 3 years old.
Old 04-03-2006, 08:15 PM
efoster_01's Avatar
well thanks for the info, that is what i was after. and yeah after i posted that when i found the thread with search, i saw the last post date.
Thanks again,
Bone
Whats the diffrence? Vinford 1994.5 - 1997 7.3L Power Stroke Diesel 10 01-09-2011 09:58 PM
difference between 1994 turbo diesel and 1994.5 powerstroke Pitchfork87 1994.5 - 1997 7.3L Power Stroke Diesel 6 04-11-2008 06:40 PM
Id'ing a turbo diesel Vinford 1994.5 - 1997 7.3L Power Stroke Diesel 44 02-24-2008 09:36 PM
Whats the diffrence? Vinford Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 6 05-12-2007 02:30 PM
94 IDI Turbo Diesel vs Powerstroke robselina 1994.5 - 1997 7.3L Power Stroke Diesel 2 05-22-2004 07:54 AM
Tags
445, 73, 94, chambers, combustion, deisel, diesels, difference, f350, ford, powerstroke, pre, t444e, turbo, whats
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
