Needed-8 groove/ 124" serpentine!!
Added an alternator.........now I need this 8 groove/ 124"-124.1"? serpentine belt to fit.
Installed a 123.3.......had to max out the tensioner and still pry the belt on.....way too tight......
Any brand is fine.........all help is appreciated.
Already tried my locals/ even googled the net...........nada so far??
Thanks all.............Ol'Ben
125?
According to my 'reliable' sources ......the tensioner travels about 1 to 1 1/2 inches on the belt length........I have the tensioner totally extended with a 123.3", So I'm adding about half that much and still should have about the right tension with a 124"......
Still looking.......thanks all.........Ol'Ben
BTW.....find an 8 groove close to 125" and I'll consider adding a larger pulley to the alternator!......(If needed.......???)
BenDare2,
Take a load of money and go to a "friendly" auto parts and explain your problem.Buy two or three belts in the general range you need & get them to agree to refund for the ones you don't use.Keep them clean and in the right sleeves.
I had this problem on a "Murcury" marine engine.Murcury wanted $96.00 for the beilt.I called around & found a place that had a good selection & picked one up that fit BETTER then the original,$24.00. Good luck!
Huffer
Huffer
OleBen,
This is exactly the problem I had.I KNEW what size I needed.I brought some different sizes home and as I was trying them on,one of them slipped on and fit better then the original.It turned out to be two inches different then what I THOUGHT would work.
Try different brands too.
Huffer
Huffer
Kit?
No kit, this is a home brew setup.......there is one kit for this engine (4.6L) for limos......and that's big bucks. It's installed below the radiator, facing the engine.........This setup uses an 'extra' belt off a double pulley on the crank......And uses powerline alternators. They will run in either direction.
Leece Nevilles may be used also.
Painful and expensive........Ol'Ben
powerstroker100
15
07-10-2015 02:46 PM
WhozeYoDaddy
07-06-2015 10:31 AM
minnesotafisherman
09-20-2012 12:22 PM
