How to add Lucas transmission fix?
Old 04-06-2004, 12:34 PM
luke_trash's Avatar
luke_trash
luke_trash is offline
I just bought the 24 oz bottle of Lucas Transmission Fix, and I'm curious about how to add the stuff.. From reading the bottle, it appears as if you're supposed to add it in ON TOP of the fully tranny.
It doesn't mention draining out 24 oz of tranny fluid??
Is this right or am I'm on crack?
Old 04-06-2004, 02:06 PM
95 F150's Avatar
95 F150
95 F150 is offline
You could just break a few of the transmission pan bolts loose and drain some fuild out then retighten them. After you do that then add the Lucas tranny treatment. Then you wont have to worry about being over full.
Old 04-06-2004, 02:10 PM
larry derouin's Avatar
larry derouin
larry derouin is offline
If ya got a marine dual action syphon pump (or any syphon pump with a six ft. hose thaqts thin enough), stick the hose down the fill tube, syphon 24 oz out and then put in the lucas. lot less chance of pulling too much out and a lot neater to boot.
Old 04-06-2004, 02:13 PM
luke_trash's Avatar
luke_trash
I've got a MityVac.. I might try that.
it's weird if you read the instructions it acts like you dump the stuff in on top of existing fluid.. I don't want to top it off, only to have the stuff immediately evaporate (or whatever it does) and leave me 24 oz shy of full.. I'll suck out and retain some ATF if I can and go for a short drive..
From Lucas' website:
One 24 oz. bottle of Lucas Transmission Fix can be added to existing fluid (a
moderate overfill is not harmful). A second bottle may be necessary in large or badly
worn transmissions.
Somehow, 3/4 quart of extra fluid still makes me a little uneasy...
Old 04-06-2004, 06:40 PM
bobcf's Avatar
bobcf
bobcf is offline
Pull the line off the trans to the cooler, put it in a bucket and run engine till you get about 24oz. On the e4od its the rear line.
Bob
Old 04-06-2004, 08:37 PM
jj292's Avatar
jj292
jj292 is offline
Does this stuff actualy work?
Old 04-06-2004, 09:29 PM
Rick78's Avatar
Rick78
Rick78 is offline
Go here, http://www.bobistheoilguy.com/ and read "The Story With Additives"
Regards, Rick
Old 04-06-2004, 10:32 PM
jj292's Avatar
jj292
jj292 is offline
From what I saw it did not mention anything about ATF.
But WHOA!!! That will sure make me think about motor and gear oils.
JJ
Old 04-07-2004, 04:11 PM
luke_trash's Avatar
luke_trash
Heh.. now you have me scared
Maybe the 'immediate' results Lucas touts come from the way it makes the oil 'sticky' so that it will work as soon as you start the engine.. but look out, once it heats up.
Maybe I'll hold off on putting this stuff in for a bit.
Old 04-07-2004, 04:27 PM
Indybroncoman's Avatar
Indybroncoman
Indybroncoman is offline
Here's the best way to add Lucas to tranny fluid. Drain tranny of ALL fluid. Take unopened bottle of Lucas, open it and pour it in the drain pan along with the old fluid. Fill transmission fluid with good quality Redline, Royal Purple, Mobil 1 or similar quality oil. Drive. I bought some of that Lucas stuff too and after reading the post on Bob's oil site and some other info, I had second thoughts. Anyway, 190,000 miles on my tranny and all is well. Good luck!
Old 04-08-2004, 06:31 AM
Lagerlot's Avatar
Lagerlot
Lagerlot is offline
wow what an eye opener that article was!! Has anyone heard anything like that about " risoline" I have been using that for a few years now in my vehicles. But I do change the oil between 3000 and 4000 miles. I have also switched to synthetic oil.
Old 04-08-2004, 10:20 AM
Indybroncoman
Similar tests have shown the same results about Rislone, Marvel Mystery Oil, Gunk et al, while some swear by these additives. Modern day oils are so well constructed (that is, the quality of base oils and additive packages are very good) that additional additives are not necessary. This is especially so if you are using synthetic fluids which are superior lubrications.
awq134
2009 - 2014 F150
11-18-2016 07:23 PM
TxMav
11-06-2016 07:28 AM
Robby Nash
03-11-2012 03:11 PM
HuntM
11-30-2010 08:45 PM
Hunt4Fun
09-15-2009 04:09 PM
Quick Reply: How to add Lucas transmission fix?
