How to add Lucas transmission fix? - Ford Truck Enthusiasts Forums
Old 04-06-2004, 01:34 PM
luke_trash's Avatar
luke_trash luke_trash is offline
luke_trash is starting off with a positive reputation.
I just bought the 24 oz bottle of Lucas Transmission Fix, and I'm curious about how to add the stuff.. From reading the bottle, it appears as if you're supposed to add it in ON TOP of the fully tranny.
It doesn't mention draining out 24 oz of tranny fluid??
Is this right or am I'm on crack?
Old 04-06-2004, 03:06 PM
95 F150 95 F150 is offline
95 F150 is starting off with a positive reputation.
You could just break a few of the transmission pan bolts loose and drain some fuild out then retighten them. After you do that then add the Lucas tranny treatment. Then you wont have to worry about being over full.
Old 04-06-2004, 03:10 PM
larry derouin larry derouin is offline
larry derouin is starting off with a positive reputation.
If ya got a marine dual action syphon pump (or any syphon pump with a six ft. hose thaqts thin enough), stick the hose down the fill tube, syphon 24 oz out and then put in the lucas. lot less chance of pulling too much out and a lot neater to boot.
Old 04-06-2004, 03:13 PM
luke_trash's Avatar
I've got a MityVac.. I might try that.
it's weird if you read the instructions it acts like you dump the stuff in on top of existing fluid.. I don't want to top it off, only to have the stuff immediately evaporate (or whatever it does) and leave me 24 oz shy of full.. I'll suck out and retain some ATF if I can and go for a short drive..
From Lucas' website:
Quote:
One 24 oz. bottle of Lucas Transmission Fix can be added to existing fluid (a
moderate overfill is not harmful). A second bottle may be necessary in large or badly
worn transmissions.
Somehow, 3/4 quart of extra fluid still makes me a little uneasy...
Old 04-06-2004, 07:40 PM
bobcf's Avatar
bobcf bobcf is offline
bobcf is starting off with a positive reputation.
Pull the line off the trans to the cooler, put it in a bucket and run engine till you get about 24oz. On the e4od its the rear line.
Bob
Old 04-06-2004, 09:37 PM
jj292's Avatar
jj292 jj292 is offline
jj292 is starting off with a positive reputation.
Does this stuff actualy work?
Old 04-06-2004, 10:29 PM
Rick78 Rick78 is offline
Rick78 is starting off with a positive reputation.
Go here, http://www.bobistheoilguy.com/ and read "The Story With Additives"
Regards, Rick
Old 04-06-2004, 11:32 PM
jj292's Avatar
From what I saw it did not mention anything about ATF.
But WHOA!!! That will sure make me think about motor and gear oils.
JJ
Old 04-07-2004, 05:11 PM
luke_trash's Avatar
Heh.. now you have me scared
Maybe the 'immediate' results Lucas touts come from the way it makes the oil 'sticky' so that it will work as soon as you start the engine.. but look out, once it heats up.
Maybe I'll hold off on putting this stuff in for a bit.
Old 04-07-2004, 05:27 PM
Indybroncoman's Avatar
Indybroncoman Indybroncoman is offline
Indybroncoman is starting off with a positive reputation.
Here's the best way to add Lucas to tranny fluid. Drain tranny of ALL fluid. Take unopened bottle of Lucas, open it and pour it in the drain pan along with the old fluid. Fill transmission fluid with good quality Redline, Royal Purple, Mobil 1 or similar quality oil. Drive. I bought some of that Lucas stuff too and after reading the post on Bob's oil site and some other info, I had second thoughts. Anyway, 190,000 miles on my tranny and all is well. Good luck!
Old 04-08-2004, 07:31 AM
Lagerlot Lagerlot is offline
Lagerlot is starting off with a positive reputation.
wow what an eye opener that article was!! Has anyone heard anything like that about " risoline" I have been using that for a few years now in my vehicles. But I do change the oil between 3000 and 4000 miles. I have also switched to synthetic oil.
Old 04-08-2004, 11:20 AM
Quote:
Similar tests have shown the same results about Rislone, Marvel Mystery Oil, Gunk et al, while some swear by these additives. Modern day oils are so well constructed (that is, the quality of base oils and additive packages are very good) that additional additives are not necessary. This is especially so if you are using synthetic fluids which are superior lubrications.
2010 STX with 4 speed (4r75E) transmission starting to slip awq134 2009 - 2014 F150 8 11-18-2016 08:23 PM
Lucas Transmission Fix HuntM Clutch, Transmission, Differential, Axle & Transfer Case 4 11-30-2010 09:45 PM
Lucas Oil Tranny Fix twisted 1978 - 1996 Big Bronco 11 11-03-2006 11:45 PM
Lucas Stop Slip or "Start" Slip? mpmccarthy Clutch, Transmission, Differential, Axle & Transfer Case 3 06-25-2004 04:32 AM
How much Lucas "stopslip" in my 86 AOD Dustin_86 Clutch, Transmission, Differential, Axle & Transfer Case 1 12-03-2003 11:37 AM
Tags
10009, 4r70w, add, added, adding, bottle, fix, fluid, ford, howto, instructions, lucas, second, slip, transmission, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
