Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 04-05-2004, 10:12 PM
ArcticRanger ArcticRanger is offline
Garage is empty, add now
ArcticRanger is starting off with a positive reputation.
backfiring after installing new timing belt?
I have a 1984 ford ranger 2wd w/ 2.0L and a 4sp.
my problem is i Just installed a new timing belt. got it all timed up, right.
but now it backfires (small Pop) out the tailpipe. does it once a revolution of the crank. Freind told me a piston could've hit a valve when the Timing belt gave. but im hoping thats not it. anybody have any ideas what it may be?
  #2 (permalink)
Old 04-06-2004, 08:22 AM
tomw tomw is offline
1985 Ford Ranger
tomw has a good reputation on FTE.tomw has a good reputation on FTE.
Well, it is not the valves hitting the pistons as this is a non-interference engine. I'd put the crank at TDC, and pull the little rubber plug you will find hidden behind the upper radiator hose. The mark on the cam pulley should line up with the pointer. You may have also not gotten the tensioner to 'snap' into place fully. (I KNOW from experience) That will put the cam timing off, and the engine will run like it has a rubber band moving the cam.. onnnnn offfff.. onnnn offff and be real lazy.
Didja check that the rotor button was pointing at the number one plug wire when you did all the work? Did you check the ignition timing after the replacement? Check the cam pointer, then the ignition timing, and let us know...
tom
__________________
It's not how hard you work, it's how much you get done. Simplificate and add lightness
  #3 (permalink)
Old 04-08-2004, 09:42 PM
yeah i have the timing set up right. tdc, mark lines up. got distrubitor pointing at #1 point. what do you mean by getting the tensioner to "snap" into place?
cant find anything about that in my chiltons
After posting I went back out and fiddled with the timing. idle was way low so turned that up. fiddled with distrubitor a bit and got running a bit better. wasnt backfiring as often. maybe once every 3-5 seconds. after that I put everything back together. Than turned off the engine. when i came back and started it up. it would run real erratic for a moment than die. so i thought "ok maybe a accidently moved the dist. while tightneing it" so i fiddle with it than "BANG" and a big flash and there goes my intake gasket. darn backfire
could a leaky intake gasket have been my problem to begin with.
  #4 (permalink)
Old 04-09-2004, 10:12 PM
bunting1 bunting1 is offline
bunting1 is starting off with a positive reputation.
I know this may sound real stupid but did you take off the distributor wires? (do you have a power pack?)
I once put them back on in the wrong order and bam! backfire like you described.
__________________
07 Ranger Supercab FX4 Level II
Fire Red/Dark Shadow
K&N Intake
Tags
1984, 23, 28, backfires, backfiring, belt, changing, engine, ford, gasket, install, installing, intake, motor, replacment, suburban, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
