Methods for lowering straight axle???
Two methods I have seen that work for the front are replacing the axle with a dropped axle, about $350 and a lot of labor to R&R the spindles/King pins.
An easier method is to either modify the leaf springs by removing some of the leafs and replacing the main leaf with a reverse eye main leaf. I talked to a guy at a car show that did this but he was not happy with the ride quality.
Myself, I replaced my front leaf springs because they had been butchered by a previous owner. I used a short smooth spring stack with reverse eyes from Mid Fifty who I found out dropped shipped them from another vendor. While I was at it I replaced the shackle pins. Gave me about a 2 1/2 inch drop on a V8 1955 F100. Also the added benefit of a smoother quieter ride from a softer spring rate and poly between the leafs. Don't forget to buy new shocks for the lowered ride height. I will get a little more drop when I replace the wheels and tires with a lower profile tire. This is sometimes overlooked, but you can change the ride height by selecting a tire with a smaller outside diameter. Like going from a light truck tire to a passenger car tire in my case.
I stayed away from mono leafs in the front because I had heard they have a stiff ride.
For the rear spring, again you can modify the springs like the front if you don't plan to haul any heavy loads. Also you can install an extended spring hanger for more drop. If you drop to much you will need to C notch the frame rails to allow room for the rear axle. Also you can replace the springs like I did in the front. My rear springs are OK but I am going to try a mono leaf with reversed eyes when I finish rebuilding the 9 inch rear. One caution about mono leafs on the rear. You have to flip the front spring hanger or they will bind and eventually break.
Happy hot rodding
Happy hot rodding
on
Originally Posted by sancochojoe
Can you put 53-55 leafs on a 51-52 truck??
Vern
Go to http://www.jalopyjournal.com look in the tech omatic section and look at the thread droppin axles writtin by Titus
Yeah its right, last night it was on page 3
http://www.jalopyjournal.com/ubbthre...=&fpart=1&vc=1 hope this link works
Crewcab Turbo
11-04-2016 06:19 AM
ultraranger
18
02-22-2016 03:27 PM
Big-old-460
40
02-29-2012 04:26 AM
