Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 12-31-2002, 02:49 PM
chspyder's Avatar
chspyder chspyder is offline
Garage is empty, add now
chspyder is starting off with a positive reputation.
1999 F250 SD PSD Fuel Mileage
Ok I have a 99 F250 PSD and I am getting 14.5 to 15 no load, with a load a little less. I am trying to find out if this is usual or not? what are you getting? and I am un modified, so if you are please note it, thanks!
Jt
__________________
2004 Ford Excursion - SD PSD 6.0 E/B 4x4, TV/DVD, Etc 1997 Ford Explorer - 5.0 Control Trac XLT
03 BMW 330i - Chipped, Lowered, Enforced, And Driven!
1986 F150 - 4X4 XL | 351 w/ Manual BD Tranny | 9" Lift So Far /w 38.5" TSLs
-For Sale-
  #2 (permalink)
Old 12-31-2002, 03:14 PM
DenverYZF DenverYZF is offline
DenverYZF is starting off with a positive reputation.
I have a stock '99 (not '99.5) Super Cab, 4x4, 6 speed, long bed, PSD, OEM tires. It seemed to get around 18-22mpg on the highway with no load, if I keep my right foot under control. Towing a 5,000 load to California and back (from Denver, CO) I got between 10-15mpg depending on terrain and speed. My truck does seem to use alot more fuel when I go faster than 70-75mph or so. I just had the motor replaced under warranty so I'm hoping that I will get even better mileage, but I don't know if that is possible.
  #3 (permalink)
Old 12-31-2002, 03:16 PM
Sam Wactor Sam Wactor is offline
Sam Wactor is starting off with a positive reputation.
It depends on your driving habits. If you are cruising the interstate around 80 mph or doing a lot of around town driving then it's about right. I average around 16 to 17 mpg with my 03 and 18 to 19 with my 95. My 95 has a chip and a down pipe which both mods did make a couple mpg difference.
__________________
95 PSD XLT SC 4X4 long bed, Diablo Chip and down pipe
03 PSD (7.3) Lariat Crew Cab FX4 Short Bed, SCMT
  #4 (permalink)
Old 01-10-2003, 07:29 AM
bigdog02 bigdog02 is offline
bigdog02 is starting off with a positive reputation.
in my 99.5 powerstroke which is stock, except for a size bigger winter tires.
Driving on long trips--i get about 18 or so, unloaded
Driving to work (80 miles a day)--I get about 16, unloaded
Putting around town, to the store, movies, etc.--15/16 in around there.
There are several things I am taking into account as well.
a size bigger tires will reduce my milage by a little bit (also the more aggressive tread)
also, here in PA, the winter diesel mix that is sold at gas stations also doesn't help the milage at all.
  #5 (permalink)
Old 01-10-2003, 07:43 AM
JoeBoost's Avatar
JoeBoost JoeBoost is offline
JoeBoost is starting off with a positive reputation.
On my 2002 Powerstroke Excursion i am seeing between 11.5 - 12.5 with the winter blend diesel. In the summer - the best i have seen is 20 on the highway. The thing that kills my MPG is that about 85% of my driving is stop and go - stop light to stop light. My truck is stock except for a superchips tuner and a AFE intake.
__________________
JoeBoost
2002 Ford Excursion XLT 4X4 7.3L PSD
2005 BigDog Bulldog Motorcycle
  #6 (permalink)
Old 01-10-2003, 09:02 AM
joeltonjet joeltonjet is offline
joeltonjet is starting off with a positive reputation.
  #7 (permalink)
Old 11-24-2006, 08:34 AM
Malakai Malakai is offline
Malakai is starting off with a positive reputation.
With my 1999 f350 psd I'm seeing 13 to 15 in town and 18 to 20 on the highway unloaded.
Malakai
  #8 (permalink)
Old 11-24-2006, 08:40 AM
2002f2507.3LPS's Avatar
2002f2507.3LPS 2002f2507.3LPS is offline
2002f2507.3LPS is starting off with a positive reputation.
2002 cc, SB, 4x4, 14ish around town, and 18-20 highway.
  #9 (permalink)
Old 11-25-2006, 12:30 AM
spunks00 spunks00 is offline
1999 Ford F-350
spunks00 is starting off with a positive reputation.
going 85mph from UT to OR got 14+ that is all the more i tested when i first brought the truck home. 99' F-350 CC LB 4x4 6spd stock...almost empty-just 2 guys and some tools just in case.
  #10 (permalink)
Old 11-25-2006, 03:53 AM
ron's power stroke's Avatar
ron's power stroke ron's power stroke is offline
ron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud of
early 99 stock till a month ago.. got 17 around town and 20 to 22 highway..put my tuner in with afe stage 2 intake and 5" strait pipe.( love the sound this thing makes).i cant keep my foot out of it and im getting 15 to 16 around town..im using b20 bio...ill get better figures december 22nd when i go to florida..
__________________
Early 99 7.3 F350 auto,TN T-4 mount with a s467 for air,SRP 1.1 for oil,H-11 stud's,"NEW" alliant 315/200 hybrids, all supplied by unlimited diesel..shimmed 910's, DI push rod's, full fuel with a fuel lab 4202,TSD sump...tuned by Gearhead..i cant wait to drop her in the truck...
http://inlinethumb43.webshots.com/50...200x200Q85.jpg
  #11 (permalink)
Old 11-25-2006, 03:55 AM
Rushmore X's Avatar
Rushmore X Rushmore X is offline
2003 Ford Excursion
Rushmore X has a great reputation on FTE.Rushmore X has a great reputation on FTE.Rushmore X has a great reputation on FTE.Rushmore X has a great reputation on FTE.Rushmore X has a great reputation on FTE.
quoting: On my 2002 Powerstroke Excursion i am seeing between 11.5 - 12.5 with the winter blend diesel. In the summer - the best i have seen is 20 on the highway. The thing that kills my MPG is that about 85% of my driving is stop and go - stop light to stop light. My truck is stock except for a superchips tuner and a AFE intake.
I thought mine was bad... I have an 03 with a 7.3. getting around 15 with the winter blend so far.
__________________
Trent - 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, redhead steering box, 6.0 trans cooler, ISSPRO & Aeroforce gauges in A-pillar, Wicked Wheel, "Bullet Proof" Transmission rebuilt by Rapid Diesel, more to follow! Gone BIO!!!
2002 TDI New Beetle - also likes Bio.
  #12 (permalink)
Old 11-25-2006, 08:27 AM
BlueOvalBoy's Avatar
BlueOvalBoy BlueOvalBoy is offline
BlueOvalBoy is starting off with a positive reputation.
Unmodified somewhat. I did jack with the powerband putting the larger tires on but I got used to it.
15 pulling the toys, 20 not pulling. Yes 20 sometimes 21.
Peace
__________________
99.5 F-250 Super-duty.
69 F-250 Ranger Camper Special.
99 Mountaineer AWD 5.0 Leather and loaded.(her's)
  #13 (permalink)
Old 11-25-2006, 08:36 AM
shenders99's Avatar
shenders99 shenders99 is offline
shenders99 is starting off with a positive reputation.
00 4x4 cc lb drw. I get 13.5 on winter blend.
__________________
-Scott
2000 F350 Lariat 7.3L CC DRW LB 4x4
Standard Mod's
Auto-Enginuity
2003 Keystone Challenger 32TKB
The Roadside Network
  #14 (permalink)
Old 11-25-2006, 04:06 PM
Smokin''s Avatar
Smokin' Smokin' is offline
1999 Ford F-250
Smokin' has a brilliant futureSmokin' has a brilliant futureSmokin' has a brilliant futureSmokin' has a brilliant futureSmokin' has a brilliant futureSmokin' has a brilliant futureSmokin' has a brilliant futureSmokin' has a brilliant futureSmokin' has a brilliant futureSmokin' has a brilliant futureSmokin' has a brilliant future
Quote:
I have an early '99. Unloaded, I do 16-18 around town depending on how much I hot rod. I experience anywhere from 20-23 on the highway unloaded as well. Loaded 6,000 lb trailor over the mountain passes, 14-15.
Perhaps its this fresh rocky mountain air BlueOvalBoy?
__________________
Lisa Not so Early '99 PSD long bed XLT supercab. 4" Pro Comp suspension lift, 315 BFG AT's on 17" Liquid Metal Gatlins, Casserly Stage 1 injectors, Terminator T-500 HPOP, BTS VB, Cale's tunes, 203* thermostat and billet housing, 6637 w/Pete's cover, CCV, Riffraff oil and fuel crossover, late turbo conversion - international bellowed up pipes, 4" turbo back exhaust, EBPV delete, Harley Davidson headlights. 200k club member.
  #15 (permalink)
Old 11-26-2006, 09:23 AM
Quote:
Yes. Thin air and all.
Peace
__________________
Tags
1999, 2003, 4x4, 73, 99, diesel, f250, ford, forums, fuel, gas, meleage, mileage, powerstroke, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
