F150 4.6 liter automatic transmission - overdrive problem - Ford Truck Enthusiasts Forums
Old 04-04-2004, 10:25 PM
chisaikobe chisaikobe is offline
chisaikobe is starting off with a positive reputation.
I just testdrove a 1998 F150 supercab with a 4.6 V8, automatic. It seemed well maintained at 102,500 miles. However, the overdrive was problematic. I noticed an automatic shifting back and forth of 4th and overdrive at speeds above 45 mph. Is this a serious transmission problem? With overdrive turned off, the truck shifted and drove smoothly. I can purchase it for $7,500. Is it worth it at that price even if the transmission needs rebuilding? I plan on towing 3000 lb boat and trailer. Thanks.
Old 04-05-2004, 12:00 AM
PaulC PaulC is offline
PaulC is starting off with a positive reputation.
Were you driving up a slight hill when this was happening? Heavy truck with small engine often means a lot of hunting between gears when climbing hills. INHO, if you're looking at a truck of this age for towing, you should look for a 5.4 which has more reserve power and a heavier-duty transmission.
Old 04-05-2004, 01:18 AM
matt_97xl matt_97xl is offline
matt_97xl is starting off with a positive reputation.
How high a speed and how was it on a flat suface.If it does it at 45-55 with light throttle it could be tranny shutter.I think it has to do with the torque converter slipping and can cost big money for a rebuild.You can't tell on hills like PaulC said.My 97 7700 had it and i was told by my mechanic to dump it or pay up.I traded at the dealer on a 98 XLT.The 97 was sent to wholesale as I couldn't sell it and screw someone.I was told it will get worse over time.Could also be a COP.Theres a lot of threads on tranny shudder so do a search.
C6 to overdrive conversion msbhvn Offroad & 4x4 27 11-16-2016 06:06 PM
4R75E transmission overdrive stumbling... 2006FOMOCO Clutch, Transmission, Differential, Axle & Transfer Case 6 11-05-2015 10:58 PM
2004 (Heritage) F150 xl 4x2 4/6L Automatic Transmission msmith1914 1997 - 2003 F150 3 09-11-2013 03:28 PM
Overdrive fuse blown wilburn 1997 - 2003 F150 10 08-28-2013 12:15 PM
AOD Transmission Question Rick_Fury 1987 - 1996 F150 & Larger F-Series Trucks 9 12-14-2011 09:42 AM
Tags
1998, 2000, 46, 46liter, 97, f150, ford, issue, od, overdrive, problems, slipping, trans, transmission, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
