gas mileage
Don't roast your tires ("brake torque" as you prefer to call it) as often, lol. Actually, if you're heavy on the gas it will cost ya. Normal driving should get ya about 15-16 in town, depending on your gearing and whether or not you have a 5spd or automatic.
On edit: are you upshifting as needed or are you driving around town @2000 rpm? That comes with a price too.
Just juicin' ya Quack!
Start with tire pressures up to the recommended max printed on the sidewall.
Change the oil if need be to 5w30.
Put in a clean air filter.
Pull & inspect the plugs. Replace if needed.
If the outside of the fuel filter has any rust on it, change it.
Keep the windows closed whenever possible.
Dealfords post covers the items that have the greatest impact on mileage as far as the vehicle goes. You can probably add a PCV valve to the list, although I'd do that since I'm sure you have no idea when it was done last. There are other things to look at, but they don't tie into mileage but instead impact reliability. Inspect heater/radiator hoses, exhaust system, battery cables, the belt, etc; just a good visual on things. Lube the locks, door/hood latch, and hood hinges. These are the basics, for the most part.
On a sidenote, I do assume it has the 195 degree t-stat in it and not a lower temp.
I've got a newer rig than yours Quack but one thing I have noticed is lugging my 4.0L is like the gas guzzling que. I've found that if I keep my RPM's around 2700 - 3000 it seems to get the best mileage by far. Just an observation.
I think I'd have to agree with Dealford too on that tune-up, I'd do the whole nine yards if you don't know for certain that the previous owner had done it, and watch that air filter, I'm convinced that pretty much all ford engines are under rated on the intake side and need to be opened up with an after market kit but at minimum open up the box and tap the filter out every now and again and/or hit it with an air compressor a time or two between replacements to keep the air ways clear.
Hope that helps, <13 MPG is tough on the pocket book with todays prices.
93 4.0 5-spd, 4x4 Reg Cab 32" tires
Before intake exhaust and chip, I was getting about 14-15 city and 18 on interstate Highway, I now get a solid 16 City and at least 19 interstate, haven't driven enough miles in the warmer weather to know for sure. Don't get the mods though to improve mileage, they will never pay for them self, but it's a nice bonus to go with that extra power you get from them.
