Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-03-2004, 10:23 PM
photomanz is starting off with a positive reputation.
Reverse Sensor Switch problem
Hello all,
Has anyone had a problem with their reverse sensor switch on the dash turning itself off? I have a 2000 X LTD 4x4. I just had the two passenger side door lock actuators replaced and now the backup sensor switch will not stay on. I press the switch from off to on and as soon as I put it in reverse it turns itself back off. Are the lock actuators wired into the backup system? This forum has been great for info since I got my X two weeks ago. Any help would be appreciated. Thanks, Alan
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-04-2004, 12:17 AM
Toreador_Diesel's Avatar
Toreador_Diesel is gaining momentum as a positive member of FTE. Toreador_Diesel is gaining momentum as a positive member of FTE.
Hmmm....I don't think the doorlocks have anything to do with the RSS. Someone at the dealership may just be a crossed wire or (as weird as it sounds) caused a short somewhere. I'm not sure at all, but I don't see why it would do that. Maybe there was a recall about this. If I'm not mistaken, 2000 (I think) was the first year for the RSS on Excursions, F-250s, and F-350s. Nonetheless, I think there is obviously somekind of quirk in the system somewhere.
__________________
FTE Excursion Forum Mod
Death Row Inmate #21
2001 X PSD Limited
6637 Filter
203* Thermo
SCT X-Cal2
Gray CPS
4 in. MBRP
Aero Turbine 4040
HPX
Sonnax/Tricumulator kit
V10 Trans Cooler
Power, Heat, Lighted, Signal TT Mirrors
6 inch PROcomp lift
315/75/16 BFG AT K/Os
9007 Bosch HIDs
4.10 Gears
WW
  #3 (permalink)
Old 04-05-2004, 02:30 PM
Boar-Ral is starting off with a positive reputation.
Every time you put the vehicle in reverse, you must disable the reverse sensing system. This is not the most ideal solution but it is what Ford decided to do. I can imagine it being a real pain when backing up a trailer and you need to go forward and reverse a few times.
__________________
2004 Ford Excursion Limited; 6.0L Powerstroke Diesel; Limited-Slip 3.73; Rear-Seat Entertainment Package; Towing Package; Kenwood Music Keg; Pioneer AVIC-80DVD Navigation System
  #4 (permalink)
Old 04-05-2004, 02:45 PM
All the same, I don't think it should just turn itself off like that. The one on my X is always comes on (in reverse) unless you turn it off. Thats why I think there may be a crossed wire somewhere. Because it seems that your system is working the other way around.
__________________
2001 X PSD Limited
6637 Filter
203* Thermo
SCT X-Cal2
Gray CPS
4 in. MBRP
Aero Turbine 4040
HPX
V10 Trans Cooler
6 inch PROcomp lift
9007 Bosch HIDs
4.10 Gears
WW
  #5 (permalink)
Old 04-05-2004, 02:47 PM
D'oh! I misread! Yes, it certainly seems that the system is acting _opposite_ of the way that it should be.
__________________
  #6 (permalink)
Old 04-05-2004, 09:42 PM
Toyman's Avatar
Toyman is gaining momentum as a positive member of FTE. Toyman is gaining momentum as a positive member of FTE.
They are designed to be ready at all times. Are you saying that when you put it in reverse the off light comes on or when you put it in reverse you have to turn it off when pulling a trailer. If I turn my switch to off and then put it in reverse it will reset and I have to turn it off again. I quess it is unclear what your situation is. Maybe it's me. Toyman
__________________
2002 Explorer
1999 F250 4X4
2000 F650
member: FTE ORDER of Blue Max
  #7 (permalink)
Old 04-05-2004, 10:01 PM
Yes Toyman,
There must be a loose wire or something because today it worked sometimes but other times it would keep turning itself off. even if you tried to turn it on, as soon as you put the truck into rev. it would light up the off position.
  #8 (permalink)
Old 04-13-2004, 10:52 PM
Hello all,
Just an update on my problem. Took the X to the dealer and they checked out the backup system and found one of the sensors went bad and it wasn't the switch. Thanks for the input.
Alan
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
