block heater plug location... 97 F250 powerstroke 7.3 - Ford Truck Enthusiasts Forums
Old 09-01-2002, 02:45 PM
basstardo's Avatar
basstardo basstardo is offline
basstardo is starting off with a positive reputation.
Old 01-15-2003, 03:13 PM
jute jute is offline
jute is starting off with a positive reputation.
Searching for block heater plug location on my 97 f250 powerstroke. It's becoming a little hard to start on cold morning and thought that I'd plug it in, but I cant locate the plug. I've been told that it is a standard item... so I guess it's there somewhere.
Any help is greatly appreciated.
Old 01-15-2003, 04:07 PM
alanscott's Avatar
alanscott alanscott is offline
alanscott is starting off with a positive reputation.
Here is a past thread detailing where to find it.
On edit:
It would probably help if I pasted the link
http://www.ford-trucks.com/dcforum/DCForumID101/1719.html
Old 01-15-2003, 07:50 PM
94turbodiesel 94turbodiesel is offline
94turbodiesel is starting off with a positive reputation.
If it's like on my IDI it's down on the bottom right of the block towards the front.
Old 01-16-2003, 07:08 AM
Thanks for the reply guys... It helped me find it.
Thanks again.
Old 01-16-2003, 09:28 AM
johnsdiesel's Avatar
johnsdiesel johnsdiesel is offline
johnsdiesel is starting off with a positive reputation.
Do yourself a favor and get a timer from Home Depot. Set it to activate the plug 2-3 hours before you drive it. It's much easier than waking up 2 hours early to plug it in.
Old 01-16-2003, 02:33 PM
bricot bricot is offline
bricot is starting off with a positive reputation.
Its a great suggestion, just went and did that, left the defroster on and the fan on high. When I went out to start it, the ice was gone from the windows and it was actually reasonably warm inside.
My plugin is inside the garage so I could use the $9 15amp heavy duty timer vs. having to get the $18 15amp outdoor timer.
Any issues with using the remote start while the block heater is plugged in for 5 - 10 minutes?
Old 01-17-2003, 04:25 AM
underp2 underp2 is offline
underp2 is starting off with a positive reputation.
It can be plugged in while running. The cooling system will take care of any heat generated.
Old 02-08-2010, 03:34 PM
jabsdb jabsdb is offline
jabsdb is starting off with a positive reputation.
Am new here and not sure how to post a question, so I thought I would do it here. Truck was plugged in and blew the breaker, not sure if the cord is bad or the block heater. How do I change the block heater if it is determined that is the problem? Then had one heck of a time getting the truck started, about11 F this morning.
2003 F350 6.0 PSD
Old 02-08-2010, 06:47 PM
wheelie31's Avatar
wheelie31 wheelie31 is offline
wheelie31 is starting off with a positive reputation.
its attached to the oil cooler, right where your oil filter attaches, And its an ellement that screws into the oil cooler.
Old 02-09-2010, 01:13 AM
donbrown donbrown is offline
donbrown is starting off with a positive reputation.
Quote:
On edit:
Ford Truck Enthusiasts Forums - Ford truck and SUV owners and enthusiasts Community And Information Source.
Link does not work !
Old 12-07-2011, 10:13 PM
sharky sharky is offline
sharky is starting off with a positive reputation.
Block Heater
Thanks donbrown! I love this site..... you just saved me 70 bucks and an hour of my life. I was looking above the starter on my 96 and thought my truck was not equipped with a heater, Then I read your post and shazam there it was. Thanks again
Old 12-07-2011, 11:10 PM
mojoman mojoman is offline
mojoman is starting off with a positive reputation.
Quote:
2003 F350 6.0 PSD
these block heater draw around 1000 Wats...you need a heavy duty cable...I use a 12 gauge 50' extension....lighter gauge would pop the breaker every time....hth
Old 12-10-2011, 11:42 AM
mklemin's Avatar
mklemin mklemin is offline
mklemin is starting off with a positive reputation.
hey this is a great post because i have been wondering about it. the last time mine was plugged in i had to jerk the plug out of the extension cord because it looked like someone was welding under my truck something shorted out obviosly. this gives me some ideas of where to look around and figure something out. thanks all!!!
Old 12-10-2011, 02:51 PM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
You should be able to get a replacement cord for the block heater without having to replace the whole element and everything. NAPA would be a good place to start looking for one.
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 03:27 PM
ooops Aerostar 5 01-14-2015 03:16 AM
... miko6810 Modular V10 (6.8l) 9 06-04-2014 06:14 AM
Albums 56panelford 1948 - 1956 F1, F100 & Larger F-Series Trucks 18 05-29-2014 11:16 PM
Brakes JBronco 1978 - 1996 Big Bronco 2 11-17-2001 05:23 AM
Tags
1995, 2002, 73, 97, block, diesel, f250, ford, hd, heater, model, plug, powerstroke, remote, specifications
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
