block heater plug location... 97 F250 powerstroke 7.3 - Page 3 - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
  #31
Old 11-04-2013, 07:12 PM
Slingnsteel Slingnsteel is offline
Slingnsteel is starting off with a positive reputation.
Heyas, this is a great thread. here is my problem. where do they usually tuck the stock plug. I looked all over mine using my iphone flashlight but could not find it.
SM
  #32
Old 12-07-2013, 06:05 PM
Furniture Doctor's Avatar
Furniture Doctor Furniture Doctor is offline
Furniture Doctor is starting off with a positive reputation.
Block heater
Inside the bumper on the driver's side.
  #33
Old 11-24-2014, 10:47 AM
roundup roundup is offline
roundup is starting off with a positive reputation.
HELP! Started 2000 F250, no heat (gauge didn't move) and fan only works on high. Changed thermostat and blower motor resistor. Still doesn't work !! Now a new problem. When adding water and antifreeze in over flow reservoir the water runs out onthe ground. Any suggestions.
  #34
Old 11-24-2014, 12:13 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE MOOSE_MACHINE is offline
MOOSE_MACHINE has a good reputation on FTE.MOOSE_MACHINE has a good reputation on FTE.
Quote:
well a good start would be to post this in the 99-03 7.3 section and start a new thread. Try to give as much "clear" information as you can. You will have to narrow down where your water leak is for anyone to give you assistance on it. Good luck and welcome to fte
  #35
Old 11-27-2014, 09:27 PM
Block heater cord
I bought #14 wire from Ace. I also replaced the plug as well. The original wire was either 16 or 18. The timer not only saves you from getting up 2 hours early but saves on your electric bill as well. Take your time and be careful and you can complete the job in less than an hour.
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 04:27 PM
ooops Aerostar 5 01-14-2015 04:16 AM
... miko6810 Modular V10 (6.8l) 9 06-04-2014 07:14 AM
Albums 56panelford 1948 - 1956 F1, F100 & Larger F-Series Trucks 18 05-30-2014 12:16 AM
Tags
1995, 2002, 73, 97, block, diesel, f250, ford, hd, heater, model, plug, powerstroke, remote, specifications
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
