Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 01-15-2003, 12:19 PM
djargyle djargyle is offline
djargyle is starting off with a positive reputation.
Remote Starter
Does it hurt to use a remote starter with a diesel. I find I get better fuel economy in the Michigan winter if I warm the truck up first, I'm thinking of getting a remote starter for convenience, is there any problems with that??
  #2 (permalink)
Old 01-15-2003, 01:33 PM
medicman medicman is offline
medicman is starting off with a positive reputation.
Remote Starter
the local place in my home town said that most remote starters will work on diesels, they usualy have a switch on them that change the normal 6 second wait to 12 second to give the glow plugs time to warm up. i would say just watch it when you start it and dont let it idle to long
  #3 (permalink)
Old 01-15-2003, 01:46 PM
johnsdiesel's Avatar
johnsdiesel johnsdiesel is offline
johnsdiesel is starting off with a positive reputation.
Remote Starter
A diesel isn't going to really warm up until you drive it. Idling cold for more than a few minutes isn't good for it anyway. The remote starter that I've seen that "work with diesels" work purely on a timer, not by the wait to start light. With the cold winters in Michigan the starter might not have a long enough delay to work with your truck. The best warm up you can do is to plug in the engine block heater and get an oil pan heater to warm up the oil. Plug them in to a timer to turn on 2-3 hours before you want to drive the truck.
__________________
1997 F250 HD PSD SuperCab 4X4 ZF5 4.10
173K miles
CMP Info1
CMP Info2
  #4 (permalink)
Old 01-15-2003, 05:46 PM
Macho Man Macho Man is offline
Macho Man is starting off with a positive reputation.
Remote Starter
I've had a remote starter on my 2000 SD since I bought it. It works directly off the dash light to trigger when to start the truck. It has worked for me every time. The only time I don't like to use it is when it drops below -10 degrees. I like to double key it to give the plugs a little extra time to heat up.
It is a two channel ASTRO-START unit so the same remote will start my truck as well as my wifes car.
  #5 (permalink)
Old 01-15-2003, 10:42 PM
Remote Starter
Your remote starter starts based on the wait to start light going off? If so, I would like some information on what you have installed. I couldn't find any that worked like that.
__________________
173K miles
CMP Info1
CMP Info2
  #6 (permalink)
Old 01-16-2003, 06:47 AM
BlueOvalBoy's Avatar
BlueOvalBoy BlueOvalBoy is offline
BlueOvalBoy is starting off with a positive reputation.
Remote Starter
Astro-Start 3006. Fairly in-expensive unit. Mine ran about 150 with 250 in labor. Same for the wife's mountaineer.
Brother in law has one on his 2000 psd.
I saw the gob of wires that needed to be hooked up and the labor was worth it.
We haven't had a lick of trouble at all.
I like the temp sentinel. I set it at 25 degrees and it starts every few hours on days where it's below freezing.
Great unit. The alarm comes with it.
www.astroflex.com
99.5 Ford Super Duty F-250 XLT 4x4. S/C L.W.B. PSD Auto loaded.
4 in. Pro-Comp lift. 35 x 12.5 x 16.5 BFG AT/KO. Weld SSII 16.5 x 9.75. Rancho 9000's Dual Front.
Warn M12000 in Semi-hidden mount. Astro-start Supreme 3006.
__________________
99.5 F-250 Super-duty.
69 F-250 Ranger Camper Special.
99 Mountaineer AWD 5.0 Leather and loaded.(her's)
  #7 (permalink)
Old 01-17-2003, 10:54 AM
bricot bricot is offline
bricot is starting off with a positive reputation.
Remote Starter
I have the Python (DEI) and it has a glow plug sensor, not a random timer, that senses when the glow plugs are ready and then fires it up.
__________________
Brian
07 EXPEDITION LTD
  #8 (permalink)
Old 01-17-2003, 11:34 AM
boggy boggy is offline
boggy is starting off with a positive reputation.
Post Remote Starter
Tags
05 , astrostart , diesel , f150 , f250 , ford , remote , start , starter , starters , truck , work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
