brakes stopped working
Get a new master cylinder, bench bleed it (before installing, fill it with fluid and pump it until only fluid comes out--it helps if you get a quality master cylinder with plastic fittings and tubes that allow you to direct the fluid right back into the cylinder), install it, then bleed the system out really well. This is also a good time to pull your drums and check for leaking wheel cylinders. Gently peel back the rubber caps on the wheel cylinders. If it's wet inside at all, replace BOTH cylinders on that axle.
Oh, and make sure that the drums are ON the vehicle when you bleed the brakes. Apparently I wasn't explicit enough in my instructions with one of my friends on that one...
drrider100
04-03-2017 11:32 AM
Travis O'Connor
10-17-2015 09:13 PM
Ajlowry
05-18-2013 02:33 PM
Dr_Doug
08-28-2002 08:42 AM
