For those with a blower on an FE
If you are putting it in a truck, be sure that the engine is centered in the engine bay. On my high boy the engine is offset to the passenger side about 2 inches. This means that anything that protrudes through the hood would be off center.
As to the rest of the question. No, there is no reason not to supercharge your FE. Typically it is not recommended to use a cast crank in a supercharged application, but it probably depends on the HP output you expect to produce. If you are really planning on zinging it, then you may want a billet crank. Use good rods and forged pistons and you should be fine.
The ONLY reason I didn't supercharge mine was the off-center thing.
-Scouder
-Scouder
I'm looking at the stroker kits at flatlander. They offer many options as far as crank rods and pistons go. In regards to the off center thing I really hadn't noticed it on my truck. I'll have to go look now. If it is off center is there a way to center the motor and tranny without having to mess with the axles? This is going into a 4x4. How much boost are you guys running on your FE's?
Which truck do you have. The problem with trying to center the engine/tranny is that the transmission hump in the cab is also off center, at least on the 73-79 series. The axles don't care.
Boost is something you should talk to your supercharger manufacturer about. It will vary with each customer depending on what they want it to do.
-Scouder
-Scouder
blowered FE
Die, you can blower an FE, they are pretty sturdy, but if you want more than 600 you might want to think about crossbolting the mains, or using one of Shoe's 'capsaddles' when they become available. As for the stroker kit from Flatlanders.....you may want to reconsider. One of our men here used an engine kit from them and has had lots of problems. Apparently their customer service is very slow, and they don't really build your stuff at all. They appear to be a virtual company that exists only on the net. They contract with whomever is convenient to build your stuff. maybe they use a good guy to do yours, maybe you get the crappy guy. Do you want to take the risk ? There are other folks who will build for you that don't have a reputation of slow service and problems. Do you need a suggestion ? Where do you live ? Maybe one of the others here lives in your area and can suggest a good shop. DF
A centrifugal blower is closer to a turbo than a roots type but it is still belt driven and feeds the carb through ductwork just like a turbo. It usually mounts about where the power steering goes but it can go anywhere there is room to hang it and still meet the bely up with the crank pulley.
