Go Back   Ford Truck Enthusiasts Forums > Misc. > Clutch, Transmission, Differential, Axle & Transfer Case
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 04-02-2004, 09:41 AM
paulbunyan22041 paulbunyan22041 is offline
Garage is empty, add now
paulbunyan22041 is starting off with a positive reputation.
11.5 inch clutch replacement
All,
I have a 360 or a 390. I pulled it and was planning on putting it into my 1970 F250. I dont know what kind of vehicle the engine was originally in but when I took the clutch off the engine and went to the parts store, it measured out to be an 11.5 inch clutch. The guy at the parts store said maybe I can still bolt up the 11 inch pressure plate to my flywheel but we tried it and the boltholes dont line up. And the kicker is that the 11.5 clutch kit costs $150 more than the regular one I and the flywheel was $200 more
My question now is...can I use a regular 11 inch clutch/pressure plate and flywheel for a 360/390 on this engine? Originally it had an 11.5 inch clutch which the parts guy said was for big trucks like F650s or F700s. Also, does anyone know of an easy way to check whether I have a truck engine (FT) ?
  #2 (permalink)
Old 04-02-2004, 07:26 PM
lee lee is offline
lee is starting off with a positive reputation.
Hi,
I replaced the stock 11" clutch with an upgrade to a 12" model. It was a direct bolt on to the existing flywheel. Here is the info:
Made by RhinoPac, Part number 07-050A 90206. There number is Technical hotline 1-800-528-6743. Total for the kit was 258.00
The only way I know of to tell the difference between a FE and an FT is to measure the crankshaft diameter. The FT is larger. Sorry but I can't remember the exact dimensions.
Hope this helps,
__________________
Lee
1970 F-250 Hi-boy 4x4, 3-inch body lift, 390FE bored .060 over, Edel RPM intake, GT profile cam, Holley Street Avenger Carb, NP-435 four speed, Heddman Hedders, Unilite dizzy mod, 36" mudders.
Tags
11, 115, 115inch, 390, 390fe, clutch, disc, f150, ford, ford115inchclutch, gt, inch, kit, perfection, set
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
