"If you bore .80 over where do you go from there?"
If your biulding a 572 stroker and bore a stock block most would assume you weighed the pitfalls and made a choice. Also your playing with a cheap disposable stock block, its not a huge loss if it gets wasted...and if it is to you....you most likely would have gambled on it....There are some DO blocks that take kindly to .080 and some may not mind .120 over, but again it boils down to doing the UT, deciding what exactly you are working with, and how much risk you are willing to assume.
BTW- Your correct on flatlanders listing of the Ford 460 Block/557 cu. in. (.080 over)
And that is on a ford block. THe 605 and up are on a FMS or IDT block.
Copy of the add from
www.flatlanderracing.com
All Stroker Kits include Crankshaft, Pistons and Rods
Key Code:
Part # Description
Crank 1 SCAT 9000 series crank w/4.500 stroke Choose numbers from this key code,
and match them to the kit #'s listed
in the table below.
Example:
Crank #1 + Rods #2 + Pistons #6
= Kit #SKF5721
To get maximum HP our of your BB Ford - take a look at our Blue Thunder Heads! ›››
Rods 2 SCAT 4340 H-Beam rod 6.800
Rods 3 Oliver billet rods 6.800
Rods 4 Manley Pro-Series I-beam rod 6.800
Rods 5 Venolia Aluminum rod 6.800
Pistons 6 JE/SRP/Wiseco/Probe/ROSS Forged F/T pistons
Pistons 7 Venolia forged pistons
Kit # Block Crank # Rods # Pistons # Price Minikits
(see below)
SKF5721 460 1 2 6 $1959 $399
SKF5722 460 1 2 7 $1959 $399
SKF5723 460 1 3 6 $2799 $399
SKF5724 460 1 3 7 $2799 $399
SKF5725 460 1 4 6 $2449 $399
SKF5726 460 1 4 7 $2449 $399
SKF5727 460 1 5 6 $2599 $399
SKF5728 460 1 5 7 $2599 $399
-Mini Kit listed Below- Add $399
Speed-Pro/JE Plasma Moly
1/16x1/16x3/16 Clevite Mains #1039P
Clevite Rods #743P
SFI Balancer #BAL-2-3
SFI Flexplate #FP460A
