2001 F250 5.4L Oil Leak in valley of engine can not find source
120K miles on a well maintained engine. I have changed oil every 5k will Mobile 1 oil. I found 2 pints of oil in the valley of the engine. We have taken the intake off to get a better look. It does not seem to be coming from the head gasket because it is clean all the way around. The shop has dusted the engine looking for cracks and none were found. Any one have any suggestions?
Thanks in advance.
Thanks in advance.
My 5.4L has a oil leak in the valley also. I found it is the oil line that runs under the intake. The fitting is leaking out of the banjo bolt located under the alternator. If you remove the alternator and use a 10mm offset wrench or socket and replace the brass washers that should stop the leak.
WOW three in one thread.......Welcome blakeb, rickyjr_44, and sd3501 to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Enjoy FTE....and
SD3501 - Are you sure that was the source of the oil leak? I asked about this at my local stealership and they say there is no oil line under the intake, only a coolant line and the knock sensor. The mechanics there said an oil leak in this area is likely the infamous head gasket problem.
Originally Posted by murph1
i have the same leak since 34000 miles..i was trying to find a print of the engine to see what all is in the valley but cannot find one..from using inspection mirrors and such it does not seem to be a head gasket on mine..anyone positive if there is an oil line in that valley?
crazytwo
25
03-20-2015 03:55 PM
tarheel007
01-10-2012 07:34 PM
