Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's SPONSORED BY:
  #1 (permalink)
Old 03-31-2004, 10:16 PM
ElScotO ElScotO is offline
Garage is empty, add now
ElScotO is starting off with a positive reputation.
i need to know if a stock 01 lightning can handle 12 boost?
I just bought my 01 ford lightning, and it says its running 8 psi of boost stock, and im thinking about buying a 6lb pulley kit for the supercharger that adds 6 psi,
can the stock internals run 12 psi or if not, what will I have todo to make sure it doesnt screw up the motor?
Thanks
Scott
  #2 (permalink)
Old 04-04-2004, 10:47 PM
sanders79's Avatar
sanders79 sanders79 is offline
sanders79 is starting off with a positive reputation.
I ve heard of L's running at 13-15 lbs of boost and being ok... go for it.
  #3 (permalink)
Old 04-05-2004, 01:46 PM
Blue_Dog Blue_Dog is offline
Blue_Dog is starting off with a positive reputation.
With no other modifications I would do a lot of research prior to moving up to 12psi. Good luck.
  #4 (permalink)
Old 04-05-2004, 10:58 PM
20BlkLightning02 20BlkLightning02 is offline
20BlkLightning02 is starting off with a positive reputation.
12 psi
with the right tune in the chip you should be ok, for awhile, i ran 4 and blew 4 rods out the side of my block. if you are thinking of running more than the stock set up, put the forged internals in it and build the lower end. ive read of lots of other L owners blowing the 01-02 motors with a chip and 4-6 lb. pulley
  #5 (permalink)
Old 04-05-2004, 11:07 PM
teamjdm.com
go to teamjdm.com and look at their kits, they have the build your own lower end kits, built short blocks, built long blocks, everything you can imagine, cams, etc
  #6 (permalink)
Old 04-11-2004, 06:09 PM
Blown318 Blown318 is offline
Blown318 is starting off with a positive reputation.
Quote:
I use to run a 5lb pulley, Chip, full exhaust......... and I ran this combo for about 23000 miles with no problems......
I have since gone to a built lower end with ported heads, KB, cams...etc.....
But I never blew my stock block.... and it took a beating......
I think sum trucks can handle it more........
  #7 (permalink)
Old 04-14-2004, 10:28 AM
skylinegtr skylinegtr is offline
skylinegtr is starting off with a positive reputation.
got boost?
i have been running a 6lb pulley with a ported blow at about 16 lbs max boost no problems yet. although i might not suggest this as I am thinking of going to a 4 lb at 14 lbs boost to have a little more pice of mind
__________________
04'Lightning, chip , 6lb pulley, CAI, MAgnaflow muffler, ported blower, denso plugs, ph spacer and more.
91' Supercoupe 2 many mods to list
  #8 (permalink)
Old 06-02-2004, 10:32 PM
CJack CJack is offline
CJack is starting off with a positive reputation.
Muscle Mustangs and Fast Fords put a Kenne Bell supercharger on at 16 pounds, and said that as long as you control detonation, you can easily run that much power.
__________________
2003 Crew Cab Short Bed F250 XLT 5.4L
  #9 (permalink)
Old 08-17-2004, 12:55 AM
Blown00Ford Blown00Ford is offline
Blown00Ford is starting off with a positive reputation.
Ive been running on a 4# lower pulley for over a year and my truck has almost 75000 miles on it. Never had a motor and it will go mid 12's. Just make sure you run good fuel and keep an ear out for detination.
Tags
12, 14, 16, 2004, 5lb, 6lb, boost, f150, ford, handle, lb, lightning, mods, power, pulley, run, stock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
