help with 1990 5.0 firing order? - Ford Truck Enthusiasts Forums
Old 03-30-2004, 09:58 AM
Crankydadjk Crankydadjk is offline
Crankydadjk is starting off with a positive reputation.
Question help with 1990 5.0 firing order?
Hello, I'm looking for help for my neighbor, he's 75 years old and started to replace his dist. cap and removed all the wires and now has gotten them crossed. What I would like is some help with the firing order and where #1 is on the block? If someone could post a pic of the block and the cap with #1 highlighted it would sure help out alot
Thanks
Crankydadjk
Last edited by Crankydadjk; 03-30-2004 at 10:09 AM. Reason: remove e-mail sentance
Old 03-30-2004, 10:29 AM
caddywhompus's Avatar
caddywhompus caddywhompus is offline
caddywhompus is starting off with a positive reputation.
On my 90 302 #1 is the front cylinder on the passenger's side bank. It goes 1-2-3-4 with four being closest to firewall. #5 is driver's side front, and 6-7-8 follow with 8 being closest to firewall.
Old 03-30-2004, 02:10 PM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
Firing order (counterclockwise on the distributor) is 1-5-4-2-6-3-7-8. Cylinders numbered as written above. Number 1 should be marked on the distributor cap itself - should be about 180 degrees from the direction the TFI plug comes out, probably around 11 o'clock when looking at the distributor from the front.
Old 03-30-2004, 02:30 PM
Smile thanks
Thank You both for your help, this answered my question
HELP! firing order question rockittsled Ranger & B-Series 5 02-07-2014 04:26 AM
Flathead 6 226 Spark plug wire diagram, Help jmadsen 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 12-20-2010 12:01 PM
Y block with a 15426378 firing order? Deadeye1963 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 26 04-29-2010 11:39 PM
92 5.8 firing order???? T/A Man 1987 - 1996 F150 & Larger F-Series Trucks 2 12-08-2004 12:41 AM
1980 302 firing order KoNFuZioN 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 06-27-2003 12:31 PM
Tags
1, 1990, 302, 50, bronco, cylinder, f150, fireing, firing, firring, ford, mustang, order, oreder, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
