Changing Fluid In M5OD 5 Speed Manual Transmission - Page 8 - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
  #106
Old 05-09-2014, 10:25 AM
BarnieTrk BarnieTrk is offline
BarnieTrk is gaining momentum as a positive member of FTE.BarnieTrk is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by itzsnitz View Post
My next project is to add filtration, a couple of three way valves, and a transmission cooler to prolong the life of my ATF (and make the flush/refill even faster). I was hoping one of you might have done something similar?
itzsnitz,
I'm not going to try to tell you what to do - but if you were asking for my opinion, I'd tell you this: Considering you DO change your ATF on a regular basis (~every 30K miles or so) I would point out that your transmission already has a filter and if I were you - I'd change the OEM filter behind the pan every other fluid change and be happy. Secondly, as long as you're NOT overworking/abusing your truck, I doubt your transmission needs an additional cooler. It should be equipped with a OEM cooler in the base of the radiator that will keep the ATF happy as well. I would suggest you use your time & $$ on other truck issues...like annually inspecting & bleeding the brakes, changing the differential gear lube every 30K miles, changing the power steering fluid every 30K miles, checking the pH / condition of the engine coolant, etc. Lastly, I wouldn't worry about trying to shorten up the time you spend on maintenance to a few minutes. Set aside a comfortable block of time, maybe an hour to complete a task and if you're done early, take the remaining time to roll around under your truck with a hand held light to inspect the condition of the driveshaft U-joints, the fuel lines, the brake lines, any exposed wiring, maybe jack up each front wheel and give it a wiggle - checking the wheel bearings, etc. I call it my 'time to bond with my truck'.....
BarnieTrk
  #107
Old 05-09-2014, 11:05 AM
itzsnitz itzsnitz is offline
itzsnitz is starting off with a positive reputation.
As far as I am aware, the M5OD-R2 ('92 F150) does not have an ATF filter. There isn't a removable pan on this transmission, so I'm a bit confused. I know the M5 series that is common between the F150/Ranger are slightly different, but I didn't think they were that different.
Isn't this only on an automatic transmissions? I can tell you for a FACT that there aren't any lines running from the trans to the radiator. OR are you saying that I could simply run lines to the radiator because it already has a transmission intercooler? I'll be doing some investigation on this, might be another difference between the F150/Ranger...
Sound advice. I have a steering upgrade planned (new pump, gearbox, tierods, linkage), so I'm not super critical about changing my PS fluid at this point. I've changed the diff lube twice (when I first purchased, and then about 30k mi later) and it doesn't seem with my driving habits that it needs to be done that often. I'm waiting to 50k for the next service to see how it compares.
My initial thought was to permanently install a filter in line with the electric pump to provide constant filtration of the particulates. Since then, I realized that (2) cheap three way valves would enable me to power-drain and power-fill the fluid. I had the thought a few days ago that I could add a small air-to-oil cooler with this system to help reduce temperature. I know there needs to be a bypass so that the ATF is not over-cooled, but what I'm looking for is if anyone has done this. I know it is overkill, but the point of my project truck is ultimate reliability. I initially planned on swapping in a ZF transmission instead of the M5R2, but it was extreme overkill for my intended use and I rather enjoy the gearing on the M5R2.
  #108
Old 05-09-2014, 11:30 AM
itzsnitz,
MY BAD!
For some reason I thought you were talking about an automatic transmission.... sorry for the confusion!
You're correct - as each of the M5OD 5-speed manual transmissions in my Rangers do not have an internal cooler nor a filter. With that being said, I've had good luck with simply changing the tranny fluid (Mercon V ATF) every 30K miles or so.
BarnieTrk
  #109
Old 07-13-2014, 12:44 PM
greasemanicure greasemanicure is offline
greasemanicure is starting off with a positive reputation.
Any guess why the guy who sent me a rebuilt M5OD said to ignore the spec and put in Valvoline 10W40??? Has been in there for about three years/39,000 miles with one change after 10,000 miles. Mine failed by the three small plugs at the top rear of the case drying out and leaking all the tranny oil everywhere but on my driveway where I could see it. Rebuiilt came with steel plugs.
  #110
Old 07-13-2014, 03:14 PM
drb1956 drb1956 is offline
drb1956 is starting off with a positive reputation.
fluid
Because people think they are SMARTER than the engineers that design these things. I have NEVER used anything but Dexron/Mercon in my trans., and I have 154,000 miles coming on the clock. OIL is not ATF!!! I have just replaced my clutch, and slave, and it was easier to drain, than to risk it running out the tail shaft once you remove the driveshaft, if you don't keep it level. Its like having a NEW truck-it shifts and drives great. I have replaced my differential fluid a couple of times, and my preference for this is Valvoline DuraBlend synthetic blend 80w90. Fluids ARE cheap-engine/trans is not!! Good maintenance is the key to long vehicle life, as I have to keep this baby running for at least a couple more years. Good Luck!!
  #111
Old 07-13-2014, 05:30 PM
R031Kona's Avatar
R031Kona R031Kona is offline
R031Kona is gaining momentum as a positive member of FTE.
itzsnitz, the cooler idea is a little different, just to point out Ford has 1 manual transmission that has a external cooler here http://www.ford-trucks.com/forums/56...al-tranny.html and it is for their 1 ton trucks, I don't think you can heat the Ranger transmission up enough to worry about.
  #112
Old 08-07-2014, 01:44 AM
deepswag22 deepswag22 is offline
deepswag22 is starting off with a positive reputation.
Wut kind transmission flud do I put in my 92 fordranger 2.3 5 speed
  #113
Old 08-07-2014, 11:18 AM
Quote:
I would suggest you use Mercon V ATF fluid in your '92 Ranger 5-speed manual transmission. It'll likely take about 3.5 quarts.
BarnieTrk
  #114
Old 08-18-2014, 07:25 PM
phoskins phoskins is offline
phoskins is gaining momentum as a positive member of FTE.phoskins is gaining momentum as a positive member of FTE.
Quote:
I've heard about a shop that rebuilds these M5ODs and puts some type of motor oil in them and always has. I have no idea why (I read about this on the F150 forum). I used Napa Dexron/Mercon III ATF in my F150 M5OD when I changed it just recently. It does shift better.
Those darned plugs !
  #115
Old 08-18-2014, 07:37 PM
customstringer's Avatar
customstringer customstringer is offline
customstringer is starting off with a positive reputation.
Guess my response on using dino oil in tranny is RTFM.
  #116
Old 08-18-2014, 09:46 PM
R031Kona's Avatar
Mercon, synthetic mercon (or dexron III ) or if still under warranty mercon V , though RedLine oils has a pretty cool sounding oil for our transmissions... Red Line Synthetic Oil - Gear Oil for Manual Transmissions - D4 ATF
  #117
Old 12-20-2014, 10:54 AM
Zoidberg's Avatar
Zoidberg Zoidberg is offline
Zoidberg is starting off with a positive reputation.
Thumbs up Thanks!
I just wanted to thank the OP and everyone else who posted helpful bits on this thread.
I just changed my fluid out for the first time in my (new to me) 1994 F150 4.9L with approx 75k miles and there was a noticeable improvement in shifting and less whine at highway speed. I used almost 4 qt. Valvoline Full synthetic Dex/Merc as specified in my owners manual.
I highly recommend doing this if you never have as it's not much more difficult or expensive than an oil change. Plus you may be surprised by the crud stuck to the drain plug!
Most important note: REMOVE FILL PLUG FIRST! This was the most difficult part as I didn't have a large enough socket but a large adjustable wrench, a lot of patience/care, and a rubber mallet got the job done.
Thanks again!
  #118
Old 01-06-2015, 11:22 PM
chrisb87 chrisb87 is offline
chrisb87 is starting off with a positive reputation.
Quote:
Originally Posted by G2IC_Wraith View Post
If I am putting a rebuilt trans in my truck, instead of trying to pump fluid into the fill hole, can't I just pour it down the hole where the shifter goes in?
Less mess? And would that hurt anything? Thanks guys.
No it wont hurt anything. Thts how i fill and top mine off, and is also great way to flush out the rest of the old atf contaminated fluid before putting the drain plug back in.
  #119
Old 01-07-2015, 09:45 AM
greenpus greenpus is offline
greenpus is starting off with a positive reputation.
Quote:
I use the Redline D4 ATF in my manual plus the power steering unit. Love it. Love it so much, that I also use it in my Toyota with Automatic. Good stuff
I tried using Redline MTL in my manual and it works great in summer but in winter, it gets too thick and I couldn't shift lol. No more MTL for my tranny...
  #120
Old 01-07-2016, 10:46 PM
Jlollis23 Jlollis23 is offline
Jlollis23 is starting off with a positive reputation.
My name is Joseph. And I was wondering how the Valvoline MaxLife DEXRON III/Mercon automatic transmission fluid work out in your m50d r2
4R100 Automatic Transmission flush-pics and video jeffreyt 1999 - 2003 7.3L Power Stroke Diesel 252 12-07-2016 08:35 PM
Mixing Mercon LV with Valvoline Max Life coolfeet Clutch, Transmission, Differential, Axle & Transfer Case 2 03-09-2016 07:48 AM
Transmission (automatic) fluid & filter 5/23/2015 dn29626 1999 - 2003 7.3L Power Stroke Diesel 6 05-24-2015 06:59 AM
Mercon V In M5OD? Nightrain Ranger & B-Series 12 07-26-2004 08:31 AM
Mobil 1 ATF - Where for best price? johnsexton Oil & Lubrication 3 07-20-2003 03:42 AM
Tags
06, 1992, change, f150, fluid, ford, m5od, manual, mazda, oil, ranger, rebuild, speed, transmission, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
