Changing Fluid In M5OD 5 Speed Manual Transmission - Page 4 - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
  #46
Old 12-30-2009, 06:59 PM
customstringer's Avatar
customstringer customstringer is offline
customstringer is starting off with a positive reputation.
Let me add another point to this thread since I checked the tranny fluid on my truck today and added some. There have been some posts indicating the fill and drain plugs are 15/16. That may be true for some versions, I don't know. However for the Mazda
M5OD, no surprise since it is Japanese, the correct socket size is 24 mm.
  #47
Old 01-19-2010, 10:51 PM
BarnieTrk BarnieTrk is offline
BarnieTrk is gaining momentum as a positive member of FTE.BarnieTrk is gaining momentum as a positive member of FTE.
Fellas,
Back on post #20, Thumper47 referred to another Tech Tip regarding the repair of the "three little shift-rail holes in the top of the tranny have rubber or synthetic push-plugs in them which get old & brittle and tend to leak."
However, the Tech Tip link [ http://www.ford-trucks.com/lc/lc.php...FLeaking5b.doc ] seems to be GONE now.
Does anyone know of another link location for some guidance on the repair of these leaking plugs?
Thanks in Advance, Guys!
BarnieTrk
  #48
Old 01-20-2010, 08:29 AM
Not sure what happened to the link but if you have the tranny down to do the clutch they are sitting right on top and just pull out. Most seem to replace them with matched sized metal engine frieze/expansion plugs. That's what I had done when my clutch was replaced.
If you are trying to do it with the tranny up they are a bear to get to, small hands and long needle nose pliers help. This link may help:
Ford Ranger Shift Rail Plug Maintenance
  #49
Old 01-20-2010, 08:40 AM
Yep, that link helped me visualize the plugs without a doubt - Thanks a bunch, CustomStringer!
BarnieTrk
  #50
Old 02-11-2010, 12:18 PM
clof2001 clof2001 is offline
clof2001 is starting off with a positive reputation.
Socket size?
Hi everyone, I have tried changing my manual trans fluid 3 times in the past 6 months. I have a 2000 F-150 5 speed 2wd. I have no idea what the model of the tranny is.
Anyway, I got about 120k miles on it now, and I know the fluid has been changed at least once (I'm the second owner, I had it done at jiffy lube or somewhere at about 70K)
So every time I get under there, I cannot for the life of me, get that drain plug off. Not even if someone had a gun to my head. The fill plug is on super tight as well. Like frozen on there. However, I've only tried changing the fluid on a cold motor/trans. Would it help if I drove it around and warmed it up a while? I had the clutch replaced about a year ago, but I really doubt they touched or changed the fluid, it wasn't the best repair facility to say the least.
Another issue. I have not been able to find the right size socket for the drain. I've tried about 5 of them, even buying a couple over at Kragen (they have no idea by the way). I don't know if it is some weird size or I'm just really missing the mark here. I tried to get it loose with a cresent wrench as a last resort, but it started to strip the plug, so I threw the brakes on that one.
Any help would be appreciated. I'm pretty good with maintenance and I have one more payment before the truck is paid off, so I'm gonna try to make this beast run as long as possible
  #51
Old 02-11-2010, 12:26 PM
Sorry guys I just realized I posted this in a Ranger & B Series forum
  #52
Old 02-11-2010, 09:32 PM
rockin300's Avatar
rockin300 rockin300 is offline
rockin300 has much to be proud ofrockin300 has much to be proud ofrockin300 has much to be proud ofrockin300 has much to be proud ofrockin300 has much to be proud ofrockin300 has much to be proud ofrockin300 has much to be proud ofrockin300 has much to be proud ofrockin300 has much to be proud of
Hey guys im buying a 91ranger exstended cab 4x4 with a 4.0L and a 5 speed tranny the probem is that when you shift it it squrts tranny fluid out the top buy the shifter
  #53
Old 02-11-2010, 09:50 PM
Quote:
It might be coming from the shift rail plugs.
Here is a link to describe the problem and the fix:
BarnieTrk
  #54
Old 02-11-2010, 11:12 PM
rockin300's Avatar
Thanks cant wait to join you guy
  #55
rockin300's Avatar
Thanks cant wait to join you guys
  #56
Old 02-12-2010, 03:57 PM
Danger_Dave's Avatar
Danger_Dave Danger_Dave is offline
Danger_Dave is gaining momentum as a positive member of FTE.
Quote:
yeah they probly buzzed it back on there with an impact gun that produces hundreds of ft lbs of torque, and they say, eh it wont hurt it if i just zap it real quck. the same method boneheads at tire shops do with lugnuts instead of torquing anything properly like they are supposed to.
So every time I get under there, I cannot for the life of me, get that drain plug off. The fill plug is on super tight as well. Like frozen on there. However, I've only tried changing the fluid on a cold motor/trans. Would it help if I drove it around and warmed it up a while?
no it wouldnt. it wont get hot enough. a propane torch will though but beware of how heat can tranfer and possibly harm something else in the process. take a long box end wrench and hit it in the proper direction with a hammer, it'll go.
yeah chances are they didnt. nobody will do anything above and beyond like that unless you specifically pay them and tell them to, or if its because they want to suck your wallet dry and they did it without your permission and state that its "normal procedure" if neither one of these things happened, your fluid is probly pitch black
  #57
Old 02-12-2010, 05:49 PM
MikeB 88's Avatar
MikeB 88 MikeB 88 is offline
MikeB 88 is gaining momentum as a positive member of FTE.
Try soaking the plug with some Liquid wrench, then take the long box wrench and hit with the hammer like Danger Dave mentioned.
  #58
Old 02-12-2010, 05:53 PM
pinger's Avatar
pinger pinger is offline
pinger is starting off with a positive reputation.
What about the rear end..do you have to take the cover off and if you do,is the gasket reuseable??At what mileage is recomended?
  #59
Old 02-12-2010, 05:59 PM
do you see a drain plug?
there is no drain plug. therefore yes you must remove the cover. no the gasket is not reusable, you will most likely destroy it while removing the cover. and if you dont, when you put the cover back on it will leak. and rtv wont either. just spend the 5 bucks for a new gasket. and torque the bolts!
when you have it apart, this is a good time to install a drain plug.
  #60
Old 02-12-2010, 07:16 PM
pinger's Avatar
No drain plug..torque at 30 ft/lbs?
4R100 Automatic Transmission flush-pics and video jeffreyt 1999 - 2003 7.3L Power Stroke Diesel 252 12-07-2016 08:35 PM
Mixing Mercon LV with Valvoline Max Life coolfeet Clutch, Transmission, Differential, Axle & Transfer Case 2 03-09-2016 07:48 AM
Transmission (automatic) fluid & filter 5/23/2015 dn29626 1999 - 2003 7.3L Power Stroke Diesel 6 05-24-2015 06:59 AM
Mercon V In M5OD? Nightrain Ranger & B-Series 12 07-26-2004 08:31 AM
Mobil 1 ATF - Where for best price? johnsexton Oil & Lubrication 3 07-20-2003 03:42 AM
Tags
06, 1992, change, f150, fluid, ford, m5od, manual, mazda, oil, ranger, rebuild, speed, transmission, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
