Changing Fluid In M5OD 5 Speed Manual Transmission - Page 3 - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
  #31
Old 11-09-2007, 08:03 AM
SweetVannilla SweetVannilla is offline
SweetVannilla is starting off with a positive reputation.
Its a manual trans. Sometimes its hard to shift into 1st and reverse. They guy at AutoZone told me I needed gear oil, short for [Regular] Mercon (thats what the dealership told me I needed for my truck). The guy at AutoZone told me what to look for under the truck, and how to do it. (he also said I could just remove the shifter and the boot, and there would be a whole to pour the oil in, but its not a god idea to do it that way cause you wouldnt know how much to pour in and that could hurt the trans).
I was also told at AutoZone that I cannot use ATF, that would also hurt my tranny. Somebody said something about "Well, if you mean 'gear oil' as in tractor oil, then thats wrong, you need Mercon ... blah blah blah" Im not completely stupid. Nor do I live ANYWHERE near a tractor (thank God). All I was asking for was a picture of that little box/pumpkin shaped whatever you guys want to name it.
I would really appreciate it.
  #32
Old 11-09-2007, 04:37 PM
markfh11q markfh11q is offline
markfh11q is starting off with a positive reputation.
I wasn't implying you were dumb or anything, it's just that I thought I could use normal gear oil at first as well, but it surprised me when I read my Haynes manual that my transmission used AT fluid.
What year, driveline, etc. do you have? If it has the M5OD transmission, then it uses AT fluid. Like I said, the Dexron/Mercron formulation from CarQuest or some such is acceptable.
  #33
Old 05-15-2009, 10:14 AM
rm56 rm56 is offline
rm56 is starting off with a positive reputation.
What transmission oil to use in a Ford 5speed manual OD
Quote:
Originally Posted by mazdaford5spd1997i4 View Post
In relation to changing the manual tranny fluid, first of all, i am assuming i have that tranny( 1997 2.3L 5spd) adn second i was wondering if there are other iol types i should use that could be bewtter or to just stay with the atf mercon..
I have a 99 F-150. I am getting ready to change my transmission fluid this weekend. I checked my Chilton repair manual awhile back and read that Ford recommends Mercon V automatic transmission fluid for the 5 speed over drive manual gearbox. I was thinking 80/90W like my other car so when I saw Mercon ATF I called a Ford dealer and spoke to a mechanic who said yes use Mercon V ATF in that transmission. As for assuming what trans you have. You need to identify it for certain and then contact someone who works on them all the time. Never assume anything when working on a vehical. A previous owner could have made changes and you could wind up destroying your transmission if you use the wrong lube. Call a Ford mechanic, tell them what trans you have and they will let you know what to use. Have a good weekend and hello to all Ford owners out there. My 1999 F-150 is my first Ford and I really like it. It rides super smooth and is rugged as hell.
RM
  #34
Old 07-26-2009, 03:45 PM
PAVEMENTMAN PAVEMENTMAN is offline
PAVEMENTMAN is starting off with a positive reputation.
I just bought some royle purple synthetic and nice smooth shifting now and also quiet.
  #35
Old 12-25-2009, 10:18 PM
Danger_Dave's Avatar
Danger_Dave Danger_Dave is offline
Danger_Dave is gaining momentum as a positive member of FTE.
another method you can use for getting the fluid into the trans without a pump is by getting a bottle of gear oil that has the nipple on the lid. take this lid and screw it onto the atf fluid bottle. voila. its cheap! and then you can use the gear oil for the differential while your at it and kill 2 birds with 1 stone.
  #36
Old 12-26-2009, 06:33 AM
MikeB 88's Avatar
MikeB 88 MikeB 88 is offline
MikeB 88 is gaining momentum as a positive member of FTE.
Nitetrain,
You said to tighten the plugs just a little more than hand tight, Is there a specified torque for the plugs?
  #37
Old 12-26-2009, 07:53 AM
customstringer's Avatar
customstringer customstringer is offline
customstringer is starting off with a positive reputation.
The torque spec for the M5OD on my Ford CD is 30-43 Ft/Lb.
  #38
Old 12-26-2009, 04:19 PM
MikeB 88's Avatar
Quote:
Thanks,
I'm going to save this thread so I can do mine
  #39
Old 12-27-2009, 08:07 PM
swamp man swamp man is offline
swamp man is starting off with a positive reputation.
Informative thread!
Got a coupla' questions...
I just got a 2000 B2500, but don't have a manual for it. Is this the tranny I have, or was there a different 5 speed offered?
The clutch was repalced fairly recently. Is it necessary to drain the tranny fluid for a clutch swap, or might it be way overdue....the only clutch replacements I've done have been in old air-cooled VW's.
TKS
  #40
Old 12-27-2009, 10:26 PM
racsan's Avatar
racsan racsan is offline
racsan is gaining momentum as a positive member of FTE.racsan is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by swamp man View Post
Informative thread!
TKS
yes, you also have a M5OD witch takes a.t.f. as the recomended fluid. id change the fluid, unless you knew for sure it had been recently done. i change mine out about every 2 years. fresh fluid is never a bad idea.
  #41
Old 12-28-2009, 06:58 AM
Informative thread!
TKS
If you had your clutch done at a decent shop or by a decent tech, I'd be real surprised if you didn't get new fluid as part of it. Unlike the old cable operated jobs in VW bugs, the M5OD has a hydraulic clutch and there is a slave cylinder in there that should be replaced while the transmission is down. Doing that is part of why I'd expect a fluid change. Whoever did your clutch would have done you no favors by leaving the old slave in there, so I'd check with them on that and the fluid swap.
  #42
Old 12-29-2009, 11:27 PM
i did a fresh change with dexIII/merc and it shifts like crap.
it actually worked better with the old black fluid that was in it.
tomorrow i am going to try and go with merconV instead.
on this forum people say to use dexIII/merc
what do you guys use for fluid in the m5od trans? how much - The Ranger Station Forums
but ford says merconV is the actual replacement LUBE REPORT: Ford Pulls the Plug on Mercon
  #43
Old 12-30-2009, 12:11 AM
racsan's Avatar
i actully like a product called syncromesh fluid from pennzoil. its not a synthetic, but is ment for manual transmissions/transaxles. royal purple has a simalr product called syncromax which is a synthetic. the pennzoil fluid is available at autozone for about $7 a qt. ive ran it for 2 years now. ive also heard of some using 5w30 motor oil before. just dont use 80-90 gear oil. ive tried various types of a.t.f.'s and not noticed any difference between types. mine is a rebuild trans, got about 4 years on it now since put in. it actually had a tag on it when i got it that saud "use 5w30 mobil1 engine oil" i did use that for the first 6 months. seemed to work fine. the only thing i dont like about the pennzoil is the 1-2 shift is kinda stiff when its really cold (below 20) but i spose its going to be a little stiff at that temp no matter whats in the case until its warmed up some. once its been driven a few miles, its as good as new. link-> http://www.stealth316.com/2-pennzoil-synchromesh.htm
  #44
Old 12-30-2009, 11:32 AM
so you have a business like an owner operator does with a big rig but do it on a much smaller scale? thats way rad!
  #45
Old 12-30-2009, 11:45 AM
As far as fluid to use, some with more expertise than me might try other things but for tranny fluid I stick straight to what Ford recommends and it varies depending on what version of the M5OD you have. That abbreviation simply stands for manual five speed overdrive, not manufacturer or year.
There are other things where I'm more confident trying aftermarket or non-specified but I'm straight on the spec for the tranny.
Transmission (automatic) fluid & filter 5/23/2015 dn29626 1999 - 2003 7.3L Power Stroke Diesel 6 05-24-2015 05:59 AM
Transmission Fluid change ... efair 1997-2006 Expedition & Navigator 24 10-07-2014 04:35 PM
How to: Transfer Case Fluid Change 97ExpGuy 1997-2006 Expedition & Navigator 35 01-01-2012 01:22 PM
'92 E4OD: Which Walmart Mercon ATF fluid should I use? 92 Red F150 1987 - 1996 F150 & Larger F-Series Trucks 7 09-30-2011 08:53 AM
Mercon V In M5OD? Nightrain Ranger & B-Series 12 07-26-2004 07:31 AM
Tags
06, 1992, change, f150, fluid, ford, m5od, manual, mazda, oil, ranger, rebuild, speed, transmission, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
