Blinking theft light... 98 explorer will not start!!! please help!! - Ford Truck Enthusiasts Forums
Old 03-29-2004, 05:31 PM
jbass jbass is offline
jbass is starting off with a positive reputation.
Angry Blinking theft light... 98 explorer will not start!!! please help!!
I need help guys!
My 98 explorer will not start!!! The "Theft" light on the dash blinks constantly. I was able to start it once, after continuously turning the switch on/off; the theft light remained constant and I was able to start it. It has just been sitting in the driveway since then! Is there anything I can do to disable the anti theft system? Any wiresI could cut? Fuses? (securilock).
I called my local ford dealership he told all they had to do was "pull a wire loose"
Any ideas would help! (my only car/truck).
Thanks
Old 03-29-2004, 07:02 PM
HomerWinzlow's Avatar
HomerWinzlow HomerWinzlow is offline
HomerWinzlow is gaining momentum as a positive member of FTE.HomerWinzlow is gaining momentum as a positive member of FTE.
Check the EEC power relay under the hood in the power distribution box. Its pretty common for that relay to go bad or for a bad connection to occur at the relay. If procesor gets no powerup then the theft light will flash and a no start condition will occur.
Old 04-03-2004, 05:34 AM
airman11 airman11 is offline
airman11 is starting off with a positive reputation.
Did you get this problem fixed? I'm struggling with the exact same thing on my daughter's mustang.
Removed the eec relay and replaced it. Still wouldn't start (anti-theft light blinking). Came back a couple of hours later and started right up.
Old 04-03-2004, 06:33 PM
It could be something as simple as a battery going bad with an intermittent problem as well. Pats transciever going bad. On some mustangs you could have a bad constant control relay module.. CCRM.
I had an Expedition yesterday that was towed in.... the damned key was missing the transponder... they had dropped it and the cap came off and the chip simply had fallen out.
Old 04-03-2004, 06:56 PM
Ran a check on the Mustang. No DTC P1260 so is not supposed to be PATS related. TSB says "...check PCM power, ground, and VREF circuits for opens or shorts. The PCM may not be operating properly."
Did get a low voltage code previously. Replaced the battery but no effect. Car is four hour drive away so trying to diagnose through my daughter long distance.
Old 04-03-2004, 07:49 PM
Ask her if she hears a buzzing noise from the right front fender area when this happens. That is where the CCRM is located. Also on the mustang there is a ground connector near the battery, a black 2 pin connector that often will over heat and the pins inside the connector can cause a power failure to the CCRM. Ive found a few like that in recent past.
Old 04-04-2004, 10:47 AM
She's taking it to a local (Savannah Ga) shop Tuesday. I had her print out this thread.
Thanks for the help. I'll let you know how it goes.
Old 04-04-2004, 10:50 AM
I lived in Savannah for severl years in the Army, great little town.
Anti-theft light jan g 1999 to 2016 Super Duty 4 11-14-2014 07:29 AM
pats anti theft no start patho44 Explorer, Sport Trac, Mountaineer & Aviator 8 09-19-2008 09:55 AM
Theft Mode ???????? jdmak68 1997-2006 Expedition & Navigator 13 10-03-2006 01:06 PM
98 Expedition won't start--Theft indicator tudelalb 1997-2006 Expedition & Navigator 3 02-17-2005 04:16 AM
What the heck is "Theft"? rotorhead Explorer, Sport Trac, Mountaineer & Aviator 15 08-26-2004 01:51 PM
Tags
98, blinking, constantly, dash, explorer, flashing, ford, light, mustang, theft
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
