Freeze Plug locations 5.0 - Ford Truck Enthusiasts Forums
Old 03-29-2004, 06:28 PM
kunder54 kunder54 is offline
kunder54 is starting off with a positive reputation.
Question Freeze Plug locations 5.0
I have a 1992 F150 with 5.0.
I have noticed that I am having to add water on a regular basis. I have no puddles under the truck. No leaking radiator or hoses that I can find. I have seen steam for a few seconds after I shut it off. This afternoon I let it run for about 15 minutes and after turning it off I could hear a hissing coming from around the exhaust manifold area on the passenger side.
I see no signs of water in the oil, truck runs great.
So I am assuming it is either a freeze plug or head gasket.
Where and how many freeze plugs does the '92 5.0 have.
kunder54
Old 03-29-2004, 06:54 PM
ALSAIR ALSAIR is offline
ALSAIR is starting off with a positive reputation.
3 on each side of the motor on the block below the heads, just below your exhaust manifold, what a cowinkiedinky!!
Al
freeze plug wtroger Ranger & B-Series 0 10-31-2016 09:16 PM
freeze plug on top of m50d help bryan5686 1987 - 1996 F150 & Larger F-Series Trucks 4 09-13-2013 01:09 AM
6.0 Powerstroke fuel filter and water kunder54 6.0L Power Stroke Diesel 1 06-15-2005 08:07 AM
5th Wheel and F250 kunder54 Fifth Wheel & Gooseneck RV Towing 25 09-01-2004 12:04 AM
E4OD towing and overdrive kunder54 Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 6 06-14-2004 08:43 PM
Tags
1996, 1997, 50, 92, engine, f150, ford, freeze, frost, location, locations, motor, plug, plugs, soft
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
