Creaking Ball joints? - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 03-29-2004, 08:19 AM
msova msova is offline
msova is starting off with a positive reputation.
2001 Ranger XLT 4x4 - 38,000 miles
I'm hearing a sort of creaking sound emanating from my front left wheel. It's not very loud and can almost be described as a ticking as well as a creaking. It is most noticeable when turning at slow speeds but can be heard somewhat when turning the wheel while at a standstill.
I've yet to take it by the dealer as they were closed, but I did take it to a reputable shop. I didn't have time to drop off so we didn't get it on a rack, but he listened to it and looked it over in the lot. He thought it was perhaps the balljoints dryting up....said they seen it a bit on newer Fords and some others.
Apparently, the B-joints aren't "lube-able", and the factory lube has sometimes been inadequate or has dried out. He said they sometimes have to deal with this and they solve it by pulling back the boot and applying oil to the b-joints. Does this sound like an ok fix for a while in lieu of replacing the joints?
Thanks
Old 03-29-2004, 11:42 AM
Sport400 Sport400 is offline
Sport400 is starting off with a positive reputation.
I recently had the same thing with my 2001 4X4. Driver side squeaking bad!. I was able to grease through the boot with a grease needle (front and back) and sweak is gone. Not sure how long this will last but I am willing to try in order to save several hundred dollars. The joints are not worn out just lacking grease.
Old 03-29-2004, 12:15 PM
stRanger706 stRanger706 is offline
stRanger706 is starting off with a positive reputation.
sounds like a great idea im gonna try that this weekend too.
Old 03-29-2004, 04:38 PM
mikek777 mikek777 is offline
mikek777 is starting off with a positive reputation.
Ball Joints with grease fittings
I have a 99 4 by 4 with 113,000 miles on it and at 50,000 miles the ball joints were so bad my frount tires were wearing on the edges. I change the ball joints and have gotten a front end e-linement ones a year and so far so good. The dealer has ball joints with grease fittings, thats the best way to go but it's not cheep.
Creaking 2wd 06 F350 firedaniel 6.0L Power Stroke Diesel 2 04-04-2015 07:31 PM
Creaking in front end while turning when not moving dcaprio 1999 to 2016 Super Duty 15 05-28-2009 01:32 AM
creaking f250 RUBICON 1999 to 2016 Super Duty 3 04-18-2007 08:42 AM
Creaking... Saleen428 1987 - 1996 F150 & Larger F-Series Trucks 12 07-31-2005 09:38 PM
Loud creaking while low speed turning Frobozz 1999 - 2003 7.3L Power Stroke Diesel 12 04-17-2005 09:42 PM
Tags
2003, ball, creaking, end, ford, front, joint, ranger
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
