2000 Ranger - Check Engine Light - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 03-27-2004, 09:19 PM
Nightrain Nightrain is offline
Nightrain is starting off with a positive reputation.
I was driving my dad's 2000 4.0L Ranger from his place today and I hit 65 in a straight,flat bottom.I was about 5 miles into my drive and then,at that moment,the Check Engine light came on.I instantly looked at my gauges and nothing was abnormal.Luckily,I was on my way to Auto Zone to pick up a filter and some oil to change his engine oil,so while I was there,I got them to pull the codes.The guy told me this...EVAP Emission Control System - Large System Leak.He said that it's possibly a stopped up converter.Evidently,it's something to do with the exhaust system or maybe the oxygen sensor.It's going to the dealer Monday morning for a warranty repair,whatever it is.But,for our sake,I would like to figure out what it is before then.
Thanks ya'll.
Nightrain
Old 03-27-2004, 09:27 PM
ranger pat's Avatar
ranger pat ranger pat is offline
ranger pat has a good reputation on FTE.ranger pat has a good reputation on FTE.
Evap Control failure could be something as simple as a loose gas cap. See if it is screwed on tight.
Can Bad/Dirty oxygen sensors make this error code come up ? hmilycar Ranger & B-Series 2 07-09-2015 12:11 PM
a code p0455 showed up today...where do I need to start? mfp4073 Ranger & B-Series 9 05-07-2015 11:25 PM
DTC code P0453 jjjetski 4 Cylinder Engines 0 01-06-2008 08:05 PM
Lucas Oil Stabilizer In M5OD Transmission? Nightrain Clutch, Transmission, Differential, Axle & Transfer Case 2 07-28-2004 05:24 AM
Towing VW Beetle Nightrain Ranger & B-Series 27 03-14-2004 10:20 PM
Tags
2000, check, engine, light, ranger
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
