95 Explorer 4.0 Hesitation
I just replaced the IAC this morning but when you hit the accelerator pedal quickly there is a second or so hesitation before it responds and it almost sounds like it may quit. It had been stalling when you attempted to accelerate quickly. We had already tried cleaning the IAC once and it helped for a month. The idle problem seems better but it still has the hesitation and no codes. Any suggestions would be appreciated greatly.
Try checking the TPS. It could also be the fuel pressure regulator.
Here's a tip. To make the engine run even better, get a can of SeaFoam from Napa or Carquest. Let the engine suck about 1/2 of the can in the engine from the PCV. Turn the engine off for about 10 minutes while the chemical breaks down the crap inside the engine. Turn the engine on and enjoy the smoke show. It's awesome!! You should get at least and extra 3 mpg.
Use the remaining can of SeaFoam and pour it in the gas tank. It'll clean the injectors.
Ellensburg 64 F350
05-14-2015 03:55 PM
adamdunn86
06-23-2014 01:49 PM
Jgostrenga49855
05-12-2014 06:32 PM
Puddy
21
06-23-2013 11:37 AM
