Overdrive Light BLINKING (F250 SuperDuty) - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 02-16-2000, 08:59 PM
campbell99 campbell99 is offline
campbell99 is starting off with a positive reputation.
Greetings,
I have a '99 F250 SuperDuty Diesel with an Automatic Transmision. There is a button on the end of the gear shift which allows you to turn off overdrive -- in other words the transmission won't shift into overdrive once you press the button.
Here's my problem. I start off driving normally. I've not done nothing to the overdrive button and the truck shifts normally into overdrive. 10-15 minutes down the road, the overdrive light (which indicates the state of the overdrive button) is FLASHING. Pressing the button doesn't stop the flashing. Once this flashing starts, the only thing I notice is a much more abrupt shift from 1 -> 2 gear. Odd.
Anyone have any experience or advice?
Regards,
kc
Old 02-16-2000, 10:27 PM
Roger_B Roger_B is offline
Roger_B is starting off with a positive reputation.
I don't know what the resolution was, but I've heard of this symptom before.. Your ford dealer probably knows how to fix it.. I would assume theres a TSB on it.
Old 02-17-2000, 01:33 AM
V10man's Avatar
V10man V10man is offline
V10man is gaining momentum as a positive member of FTE.V10man is gaining momentum as a positive member of FTE.
The blinking light means the computer for the tranny senses a problem. Have the dealer look at it asap.
Old 02-17-2000, 02:11 AM
dad3838 dad3838 is offline
dad3838 is starting off with a positive reputation.
Old 07-02-2006, 10:00 PM
ICHTHUS ICHTHUS is offline
ICHTHUS is starting off with a positive reputation.
Angry
2002 7.3 PSD with blinking O/D light = $4100 new tranny
Old 07-03-2006, 07:54 AM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
... Welcome to Ford Truck Enthusiasts!
This happens to be an old thread, however stick around and someone will be by to talk with you.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
..See you on the boards.
Old 07-03-2006, 08:36 AM
toypuller toypuller is offline
toypuller is starting off with a positive reputation.
I had the same problem with my 05 F 250 that started about 50 miles after I picked it up.
Was told it was a "shifting solonoid " inside the tranny. They had to drop the pan to get to it, but it was a simple fix.
It was covered under warranty so I can't tell you what it would have cost.
Old 07-03-2006, 09:38 AM
calhounsF250 calhounsF250 is offline
calhounsF250 is starting off with a positive reputation.
my old 99 done the same thing and the sensor on top of the rear end had gone bad. it's easy to find it's right on top of the rear chunk, you have to take it out to add rear end dope, it has a magnet on the end to catch metal fragments. i know this sounds confusing but get under your truck and you'll see what i'm talking about. i think the sensor is only about 20 bucks from powerstrokeshop.com. PM me if you still can't find the sensor.
Old 07-04-2006, 09:13 AM
Casey Casey is offline
Casey is gaining momentum as a positive member of FTE.
The only way to know what's going on is have the code read. When the OD light flashes an error code is stored in the computer's memory. A Ford specific scan tool is needed. The auto parts stores that say they will read codes free usually can't read a transmission code.
Old 07-04-2006, 09:36 AM
captchas captchas is offline
Guest
captchas has a great reputation on FTE.captchas has a great reputation on FTE.captchas has a great reputation on FTE.captchas has a great reputation on FTE.
you need to find some one with a shop type scaner to read the trans codes. thats the starting point. not running and getting a trans rebuild . the other guys have said as it should be started every time. read the codes first.
Old 10-05-2006, 01:36 PM
critterz critterz is offline
critterz is starting off with a positive reputation.
did you find the issue to your overdrive problem? I am having the exact same issue with my '98 ranger. drives fine until I hit about 50-60 mph then o/d shuts off and shifts very hard when I slow down. The shift button does nothing at this point. I have changed atf, oil, filters, plugs and wires, etc to no avail....I am leaning towards the speed sensor but wondered if you got your issue resolved.
Old 10-05-2006, 02:51 PM
tvsjr tvsjr is offline
tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.
If your transmission is shifting hard and the lights are flashing, you're driving a ticking timebomb. The more you drive, the more damage. Take it to a dealer.
Old 10-05-2006, 06:00 PM
BPofMD's Avatar
BPofMD BPofMD is offline
Posting Legend
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
Probably a bad VSS sensor at top of the differential....but as others have said, don't throw parts at the problem, have the codes read and fix it the first time.
Old 10-05-2006, 11:43 PM
Saddle Tramp 57 Saddle Tramp 57 is offline
Saddle Tramp 57 is starting off with a positive reputation.
I had same problem with F350. Tried new VSS and cleaned MAF but still blinked. New transmission - quit blinking. It wouldn't throw any codes.
Old 10-06-2006, 08:00 AM
Quote:
Sure it did. You must not have had the right scan tool to be able to read Ford transmission codes.
New Rebuilt E4OD, Has Overdrive cold, No Overdrive After Warm Transam461 1987 - 1996 F150 & Larger F-Series Trucks 7 09-10-2016 01:58 PM
4R70W no OD after rebuild RVanPeeren Clutch, Transmission, Differential, Axle & Transfer Case 7 09-06-2014 04:06 PM
Overdrive button on gear shift amyr61 1999 to 2016 Super Duty 2 08-07-2011 06:32 PM
Overdrive Button ttttmaxx 1994.5 - 1997 7.3L Power Stroke Diesel 6 11-09-2007 11:14 AM
96 250 Overdrive button flashing JoeLindaMiller 1987 - 1996 F150 & Larger F-Series Trucks 1 10-25-2004 12:10 AM
Tags
2000, 2001, blinking, blinks, f150, f250, flashing, ford, light, overdrive, ranger, slips, superduty, truck, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
