Tires on my 02 Ranger Edge? What will fit without modification? - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 03-26-2004, 09:50 PM
hoosiermike hoosiermike is offline
hoosiermike is starting off with a positive reputation.
I'm just curious if anyone knows the max tire size that will fit on my 02 Ranger Edge 4X2 without modification. I want to use my stock rims and i'd prefer not to lift the truck any higher that stock.
Old 03-26-2004, 10:00 PM
Higgin Higgin is offline
Higgin is starting off with a positive reputation.
The 4x2 ranger edge is still higher up like the 4x4 right? I don't know if it will help any, but I have a 1998 Ranger 4x4, and I fit 265/75-16's on with no problem and no lifting. And they never rub. And I would imagine that if all the edges are the same height, you could probably fit them too. But if not, definatly 245/75-16'2.
Old 03-26-2004, 10:15 PM
I believe the $x2 edges sit as high as the 4x4. 16s would be nice but i really want to keep the stock rims and get some mud tires. i would like to get some 31s or 32s if i can get them to fit.
Old 03-26-2004, 10:28 PM
What size wheels did the fx4's come with? Were they 17s? or 15s? Seems liek the Fx4 F-150s had 17s now that i think of it, and seems like the rangers were the same. Well, whatever you have, if the 2wd is as tall as the 4wd, and i think it is, you should be able to fit 31's with no problem. I think my 265/75-16's came out to being 31.5 inches tall. Whatever tires you want, go onto tirerack.com and look up the tire and size. On their website somewhere, you can look up the Overall Diameter of the tire you want. That is really what you need to look at. But anyway, good luck on getting some nice tires
Old 03-26-2004, 10:38 PM
Thanks for replying Higgin. Im gonna look in to getting some 31s. I like tirerack but i think i will go to tires.com because they off free shipping.
Old 03-27-2004, 01:05 PM
flyingdutchman's Avatar
flyingdutchman flyingdutchman is offline
flyingdutchman is starting off with a positive reputation.
You can fit 31's. I hve 31's in my 2001 2WD and they fit with slight rub on the left side.
Old 03-28-2004, 08:38 PM
soksniffer's Avatar
soksniffer soksniffer is offline
soksniffer is starting off with a positive reputation.
You should be able to fit up to 33x10.50R015 with only minimal rubbing at full flex/full turning. If you want to go wider, you can squeeze in 32x11.50R15. In either case you'll have remove the front mud flaps (if you've got 'em).
biggest tire on a stock 4x4 edge Diesel_Brad Ranger & B-Series 6 12-09-2009 10:03 PM
2001 ranger 2 wheel drive wheel size glonine Ranger & B-Series 3 12-26-2008 04:23 PM
Simple Question Eye3BigDon Ranger & B-Series 4 10-03-2006 12:26 PM
Body lifts for 2004 2WD EDGE? Mirage Offroad & 4x4 3 07-12-2004 06:47 PM
03 edge tires mal7 Brakes, Steering, Suspension, Tires, & Wheels 1 02-27-2003 11:26 AM
Tags
32x1150r15, fit, ford, ranger, tires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
