2.9L Ford Bronco II 1986 - Page 2 - Ford Truck Enthusiasts Forums
Old 04-05-2004, 06:28 PM
mrshorty mrshorty is offline
mrshorty is gaining momentum as a positive member of FTE.
Instructions for EEC-IV self-tests (aka "pulling codes") www.dalidesign.com/hbook/eectest.html
Old 04-11-2004, 12:00 AM
GrayRanger4x4's Avatar
GrayRanger4x4 GrayRanger4x4 is offline
GrayRanger4x4 is gaining momentum as a positive member of FTE.GrayRanger4x4 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by Raidy
Yep. Two wires. One large fat one, like the positive battery cable; and one very small one coming from the same terminal block on the battery; Both going to ground on the truck frame, essentially.
I've checked wires all over the truck for corrosion, nipped them and rewired any I found that were bad or appeared to be in rough shape. But it doesn't seem to help. The truck is still doing the garbage it's doing.
I dont know if this will fix your problem,but the main neg battery cable{BIG ONE} needs to be grounded to the Engine.The motor mounts have rubber in them and do not conduct elec. real good,also check and make sure that your ground strap from the back of the engine to the firewall is good.JMO
Old 04-11-2004, 05:33 PM
_rich_ _rich_ is offline
_rich_ is starting off with a positive reputation.
Strange as it may be, this does sound very similar to the way my bad fuel pump acted. Ran fine cold, wouldn't run worth crap when warm. New fuel pump, and the problem hasn't been back in the past 50k miles.
Old 04-22-2004, 07:06 AM
Raidy.What did you find? I would like to know.
Old 05-12-2010, 03:20 AM
Denis Stirling Denis Stirling is offline
Denis Stirling is starting off with a positive reputation.
I had the same problem and it was the pressure regulator . Replaced with a 45psi unit and it solved the problem
Old 07-03-2010, 02:54 PM
MLRTME1's Avatar
MLRTME1 MLRTME1 is offline
MLRTME1 is starting off with a positive reputation.
I am voting fuel pressure loss. Also, might check the MAP sensor since it detects engine load from vacuum. Check the rest of the vacuum lines while your at it.
Old 08-17-2010, 03:13 PM
broncIIohner broncIIohner is offline
broncIIohner is starting off with a positive reputation.
86 Bronc II with same prob as Raidy
I have the same prob as Raidy. Took 15 hours to make a 6 1/2 hr drive in the heat, stopping at 10-45 minute intervals for the car to sit long enough to run again. The engine is not overheating, new in-tank fuel pump. High pressure fuel pump tested good, and battery wiring seems good. A friend told me this was a common prob with early Bronco's. The early computer board thinks the engine is hot and shuts off the fuel, and that is exactly what it feels like. It feels like you're running out of gas. What and where would that computer board be? Any suggestions?
Old 08-18-2010, 02:56 PM
TigerDan's Avatar
TigerDan TigerDan is offline
TigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputation
I think what your friend is referring to as the computer board is the ECU, which is located behind the passenger side kick panel in the cab. But ECU problems are rare, it's usually a sensor or actuator that causes the problem. The first thing to do is check for fault codes, which can be done with a code reader (about 30 bucks or so) or by more primitive methods as detailed here:
Ford Fuel Injection How To Run a Self-Test
But also, be sure to check everything already mentioned in this thread. Specifically, I'd tend to suspect your ignition module.
Old 02-19-2014, 08:44 PM
jojojesse jojojesse is offline
jojojesse is starting off with a positive reputation.
bronco running rich
i have a 86 bronco 2 with a 2.9 engine, I rebuild the engine and everything was find for about 200 miles, then it started missing and running real rich. i replaced the egr valve the fuel pressure regulator, the high pressure fuel pump, new plugs and it still running rich. Help
Old 02-20-2014, 09:39 PM
jimbbski jimbbski is offline
jimbbski is starting off with a positive reputation.
Quote:
How old is the O2 sensor? This controls the A/F ratio. Also check for any leaks in the intake system. How old are the fuel injectors, they could be sticking open. Leaks in the exhaust system before the O2 can also cause a problem.
1994 F-150 Skip Randomx232 1987 - 1996 F150 & Larger F-Series Trucks 3 03-14-2016 09:26 AM
Truck dies randomly, pull a battery wire truck dies. Good alternator BrokeItAgain713 1987 - 1996 F150 & Larger F-Series Trucks 4 03-03-2016 08:41 AM
Long cranking and cold starting woes el chingadero Ford Inline Six, 200, 250, 4.9L / 300 4 10-26-2015 03:24 PM
88 ranger 2.9L idle issue McStein Ranger & B-Series 8 03-18-2015 10:26 AM
Truck stalls after start-up... 85F250Diesel Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 10-29-2009 09:59 AM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
1986, acts, battery, bronco, cable, eec, erratic, ford, post, spark, start, terminal, time, truck, turns
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
