Replace my cast iron SCJ intake with an aluminum one?
I have a 429SCJ block/Heads/Intake with a 460 crank. I would really like to save some weight by putting on an aluminum dual plane intake, but I want it to have the same size ports as the original. Who makes an intake?
I emailed Edelbrock's tech department about this and they said:
Not sure. Our Performer RPM intake (Part number 7166) will definitely work with a CJ intake, but mentions nothing about a SCJ intake. If it helps, the port exit dimensions are 1.76” x 2.06”. That way you can match it up to your intake and see if we’re close.
Are those the dimensions of the ports on my SCJ heads?
Thanks!
Ben
Thanks!
Ben
The performer may handle a street engine, but the Stealth will outdo the performer or Performer RPM in BOTH hp AND torque. There is no reason, that I see, why a person would go with the performer or even the performer RPM. The stealth is simply a better intake. Especially in a 460 or bigger engine which will have higher volume air requirements.
From what I've read on other sites, the Performer RPM and the Stealth are pretty evenly matched as far as flow and power numbers. The Performer, IMO, is just a lighter (aluminum)version of a stock iron intake. The Performer RPM is made to be used in applications from 1500-6500 rpm, the Performer from idle-5000 and the Stealth from idle-6500 rpm.
I guess I was asleep at the wheel there, they are the same. But I don't know if enough material is available the open them up to the size of the CJ/SCJ heads. I know you can open up the Victor. With the stealth you get a manifold that is close to the CJ port size out of the box, very little require if any.
Port exit dimensions:
Standard Head Intake Ports - 1.85" x 2.56"
CJ/SCJ Head Intake Ports - 2.12" x 2.86"
Air-Gap ports - 1.76" x 2.06"
CJ/SCJ Stealth ports - 2.20" x 2.49"
Sorry for the confusion. More sleep might help if I could find the time. Maybe a 36 hour days, ya thats the ticket.
uniwagon
04-18-2015 11:48 PM
icuhatn99
02-14-2006 10:33 AM
BBF250
11-30-2005 12:06 PM
chesid24
02-10-2002 12:11 AM
