Replace serpentine belt at what mileage? - Ford Truck Enthusiasts Forums
Old 03-26-2004, 11:54 AM
Ranger Lance Ranger Lance is offline
Ranger Lance is starting off with a positive reputation.
I'm fast approaching 60K miles on my 2000 Ranger XLT, 3.0 flex and wondering if anyone has seen a recommended change interval on the serpentine?
For those who have had their serpentine's shred or break on them what was the time/mileage?
Thanks,
Old 03-26-2004, 12:26 PM
Bob Ayers Bob Ayers is offline
Bob Ayers has a good reputation on FTE.Bob Ayers has a good reputation on FTE.Bob Ayers has a good reputation on FTE.
I changed my serentine belt at about 50K miles. This is on a 1999 3.0L FFV. It was starting to get some surface cracks, and I didn't want to take any chances with it.
Old 03-26-2004, 06:38 PM
Delta Delta is offline
Delta is starting off with a positive reputation.
I would change it. Cheap insurance!
Old 03-27-2004, 09:17 AM
low-side low-side is offline
low-side is starting off with a positive reputation.
Service interval on quality serpentines is 50K. Be careful because there are cheap ones out there that will fail between 10K to 20K.
Old 03-27-2004, 10:20 AM
tomw tomw is offline
tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.
Per FoMoCo, if you get cracks in lands on the rubber side of the belt, this is normal. But, if you get chunks missing, replace the belt. Some will tell you that cracks are a sign to replace the belt. Not necessarily true.
tom
Old 03-28-2004, 10:38 AM
R6elmo R6elmo is offline
R6elmo is starting off with a positive reputation.
tom is right. if you get cracks on the other side of the belt, not where the v-grooves are, i would change the belt as well. My factory one lasted all the way to 85K as the previous owner never changed it. I would change it though as it's cheap insurance and if that thing fails...u'll be on the side of the road cursing.
Old 03-28-2004, 01:59 PM
Yep it just got added to the 60K mile maintenance list!
Thanks Guys
Old 03-29-2004, 07:33 PM
jcork jcork is offline
jcork is starting off with a positive reputation.
Quote:
I just replaced mine. The original was a solid looking belt with a smooth outer surface (but it was starting to crack underneath). The new one is broken up into several bands and looks more like a snow tire, on both sides.
How can you tell the good from the bad?
Old 03-29-2004, 09:09 PM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to behold
By the time you can actually visually tell that a belt is shot, then it's already been bad for several thousand miles. They should be replaced every 60K. This is particularly true for the newer "gator" and "poly cog" designs which are fine belts but they make it harder to discern cracks and splits, etc. Sure they can last longer, but as elmo said, why run the risk of being stranded?
Old 04-02-2004, 09:34 AM
rangersvt04's Avatar
rangersvt04 rangersvt04 is offline
rangersvt04 is gaining momentum as a positive member of FTE.
im gonna change mine (69k on a 96)
Old 04-24-2004, 07:30 PM
fifthcircle fifthcircle is offline
fifthcircle is starting off with a positive reputation.
just replaced mine. it's the second belt for my truck at 120,000 miles. the motorcraft belt was squeeling like a banshee!!! so I guess the 60k is about right huh.
Old 05-01-2004, 08:54 PM
Beast12's Avatar
Beast12 Beast12 is offline
Beast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant future
Just a tip: When replacing your belt put your old one behind or under your seat. You never know.....................
-Matt
460 serpentine pulley bigcrunch 1987 - 1996 F150 & Larger F-Series Trucks 3 06-15-2016 06:45 PM
serpentine belt size snasby57 Ranger & B-Series 5 02-22-2010 12:54 AM
Serpentine Belt Tensioner 2000 Ranger 4X4 Bajsin Ranger & B-Series 21 02-10-2010 10:07 PM
Serpentine belt replacement arctic10 Explorer, Sport Trac, Mountaineer & Aviator 3 09-20-2007 07:55 AM
Serpentine belt on an earlier motor banjopicker66 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 8 03-29-2005 12:21 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
2003, 2004, 30, belt, change, drive, f150, ford, fprd, interval, mileage, ranger, recommended, replace, replacement, serpantine, serpentine
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
