What are the signs of bad u-joints? - Ford Truck Enthusiasts Forums
Old 03-26-2004, 12:40 AM
Bimmer ese's Avatar
Bimmer ese Bimmer ese is offline
Bimmer ese is starting off with a positive reputation.
Question What are the signs of bad u-joints?
Hello,
Just out of curiousity, what are the signs of bad universal joints? My truck is approaching 10 years of age with under 90,000 miles on it. Is it a normal scheduled maintenance item after a certain mileage (like a fuel filter)? I notice from time to time, the truck will shake when taking off in first gear. Other than that, the truck drives great.
Cheers,
Dan
Old 03-26-2004, 12:46 AM
Matts72's Avatar
Matts72 Matts72 is offline
Matts72 has a good reputation on FTE.Matts72 has a good reputation on FTE.Matts72 has a good reputation on FTE.
just keep them greased, you have to pull them to know if they are actually bad. You can give the driveshaft a sharp twist by hand, if there is a lot of movement (more than 3/8") then your joints are shot.
I'd only use GMB Performance or Precision Machine Ujoints.
Old 03-26-2004, 01:06 AM
c96drumm's Avatar
c96drumm c96drumm is offline
c96drumm is starting off with a positive reputation.
Last set that I wore out got to where I'd hear a clank when I started to back up. They didn't seem worn really bad, but new u-joints got rid of the clank.
Bimmer ese's Avatar
Thanks for the quick reply. Did a quick check, and there's no movement whatsoever.
Wondered why this post was moved. I thought UV joint symptoms fell into a "general" category. Oh well.
Happy motoring!
Old 03-26-2004, 02:39 AM
akford351 akford351 is offline
akford351 is starting off with a positive reputation.
Other than the physical check... You'll have a noticable "clank" or "*****" when shifting and going in reverse. And at certain mph you'll feel vibration or shaking.
Old 03-26-2004, 04:47 AM
PatsPOS PatsPOS is offline
PatsPOS is starting off with a positive reputation.
IF there are ANY visible signs of play in a u-joint, it needs to be replaced
Old 03-26-2004, 11:08 AM
wlihntr's Avatar
wlihntr wlihntr is offline
wlihntr has a good reputation on FTE.wlihntr has a good reputation on FTE.
the only thing i have owened that the u-joints went out on was my '73 mach I and they went out every 6 months or so, and i could tell when they were bad. i will try to explain this; when they were bad and you had pressure on the driveline(accelerating or deaccelerating) you could not tell, but if you "costed" the driveline in other words gave it enough gas to take any resistance off the driveline you could feel a vibration and when i felt that i knew my u-joints were bad.
Old 03-26-2004, 11:50 AM
Talyn's Avatar
Talyn Talyn is offline
Talyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud of
Remember though, the feel of a lil movement inside the truck can be due to the rear end. In manual transmissions, they have a little bit more movement. (this is what i'm told)
Then again, if your like me, your transmission is going. hahah! POS M5OD.
Old 03-26-2004, 11:51 AM
Slade901's Avatar
Slade901 Slade901 is offline
Slade901 is starting off with a positive reputation.
Just make sure that motor mounts and transmission mount are fine.
Old 03-26-2004, 08:34 PM
Matts72's Avatar
There will be a little play in the system, for gear backlash in the rear differential, and play in the tailshaft or transfercase.
Old 03-26-2004, 10:23 PM
1982fordf100's Avatar
1982fordf100 1982fordf100 is offline
1982fordf100 is starting off with a positive reputation.
I've notice sometimes that they will sqeak at low speeds. I have heard mine do that right before they get ready to fail. The way I listen for that is to keep the rear sliding window open and start going slow in first gear. Fred
Old 03-27-2004, 12:20 PM
Talyn's Avatar
means you dont greeze em enough fred. :P
Old 03-27-2004, 09:46 PM
I bought lifetime replacement u-joints for my truck. They didn't have grease fittings in them. So I can't grease them. Go figure. Otherwise I would grease them if they had grease zerks.
Old 03-27-2004, 11:02 PM
MustangGT221's Avatar
MustangGT221 MustangGT221 is offline
MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.
There are greaseable and non-greaseable types. The only way to know if the joint needs to be replaced is if you get under the truck and grab the two yokes and try to move them around. Look for movement in the joint. I grease mine everytime I change the oil, water gets in there when it rains and wears them out. The joints will usually seem fine, and then all of a sudden eat themselves within a few thousand miles. Most of U-joint failures come from lack of lubrication.
Old 03-28-2004, 01:36 PM
Tylus's Avatar
Tylus Tylus is offline
Nuclear Machinist Mate
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
you can always tell when they break..sorry couldn't resist. I have always noticed a "clicking" sound when they are getting bad. if you off-road, you should check them more often because of the extra stresses
oh yeah, and the u-joints for the front driveshaft are interchangeable, so if you ever break a rear one, just take one off the front to get you home
signs of a bad icp? bulldog88 1999 - 2003 7.3L Power Stroke Diesel 17 02-14-2015 07:41 AM
Is this the sign of a shot tie rod joint? madpogue 1987 - 1996 F150 & Larger F-Series Trucks 0 07-14-2014 10:48 PM
Signs of a bad EGR valve?? ravens fan 1987 - 1996 F150 & Larger F-Series Trucks 2 03-21-2013 09:26 AM
Bad ball joint? GLF250 1999 to 2016 Super Duty 2 03-24-2008 10:17 AM
bad ball joint warning signs? swenson 1978 - 1996 Big Bronco 9 05-30-2003 10:01 PM
Tags
2002, bad, dsm, f150, f250, ford, gmb, good, joint, shifting, symptoms, transmission, trouble, ujoint, ujoints, worn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
