ranger Tach hook up - Ford Truck Enthusiasts Forums
ranger Tach hook up
Old 03-25-2004, 10:31 PM
My Poor Poor Ranger My Poor Poor Ranger is offline
My Poor Poor Ranger is starting off with a positive reputation.
ranger Tach hook up
okay this might be a stupid question. i have an 84 ford ranger 2.8L with a TFI ignition coil. Which wire do i hook my green wire up to??????? or does it already have a tach terminal?? PLZ HELP ME
Old 03-26-2004, 10:09 AM
I know someones gotta know the answer to this question. come on help
Old 03-26-2004, 08:27 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
You should have three wires going to the coil. The fat one for the dist cap, and two smaller ones. One of the smaller wires will be positive, and the other negative. You want the negative wire. If it's not marked, just try one. if it's the positive, the tach won't work, and nothing will be harmed. Just swap it to the other one and it should work.
Old 03-26-2004, 09:12 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
I'm pretty sure it says TACH on the coil module.
Old 03-28-2004, 02:17 PM
siad nothing bout tach on the coil but we finally figures it out. and there are 5 wires. my dist. wire then 4 others but with a litlle cuttin and some butt conecters we finally found the one and it works great
Davis DUI ignition (Help with factory tach) misleib 1978 - 1996 Big Bronco 1 08-24-2015 11:22 AM
Tach not working drpaul311 1994.5 - 1997 7.3L Power Stroke Diesel 59 12-21-2014 01:22 AM
Factory tach wiring questions. scottscott 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 04-22-2010 05:08 PM
tachometer installation adidasab03 Ranger & B-Series 8 07-16-2003 01:16 PM
How do you hook up a tach? alpine 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 11-10-2002 04:16 AM
Tags
1994, 1996, 2000, 28, 28l, 96, coil, ford, hook, installation, ranger, tach, tachometer, tfi, wont, work, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
