function of a throttle body - Ford Truck Enthusiasts Forums
Old 03-25-2004, 06:49 PM
nastruk95 nastruk95 is offline
nastruk95 is starting off with a positive reputation.
Arrow function of a throttle body
I know many people have opinions if the aftermarket throttle bodies work or not, but suppose you were to make one from 1.5inch aluminum without the threads in the middle. Would it do anyhting on a fuel injection?
Old 03-25-2004, 09:00 PM
Phrogman46's Avatar
Phrogman46 Phrogman46 is offline
Phrogman46 is starting off with a positive reputation.
Well I don't think that it would be worth the time to make a new TB yourself. I'm not doubting your ability but it would not be so easy IMO. The aftermarket TB's work if your engine can use the air that a larger hole can give you. I'm new to the I6 but most people have said a stock engine it's a waist of money.
Hope that helps
Chris
Old 03-25-2004, 10:25 PM
faroffthetrack's Avatar
faroffthetrack faroffthetrack is offline
faroffthetrack is starting off with a positive reputation.
you whould need places to mount the iac valve, tps, fule vapor purge lines ect...
some chick posted that she switched out her tb with one from a 490, said it gave some nice results altho rough idle and whatnot
Old 03-26-2004, 03:12 AM
optikal illushun's Avatar
optikal illushun optikal illushun is offline
optikal illushun is gaining momentum as a positive member of FTE.
the TB isnt the restriction on a 300, its the head itself. the TB just lets air in depending on throttle position and a larger one is a) not worth the work and b) not gunna make a different besides a slight throttle inscrease. same thing w/ a TB spacer.
Old 03-26-2004, 12:53 PM
how exactly does a throttle body work on fuel injection? I wouldn't see why there would be any difference?
Old 03-26-2004, 07:44 PM
Silver Streak Silver Streak is offline
Silver Streak is gaining momentum as a positive member of FTE.
Are you talking about a new TB, or just a TB spacer? Either way, spend your time and money elsewhere. The TB spacers work nicely on carbureted engines and TBI engines. With port injection any benefit they provide has disapeared by the time fuel meets air.
Old 03-26-2004, 09:06 PM
Phrogman46's Avatar
Quote:
Well this is how it works It controls the amount of air allowed to come in to the engine. If you removed the TB and started the engine the motor would rev out of control.
FYI
The TB is closed when you have you foot off the gas, the idle control is done with a small valve on the intake called the air idle control valve.
Also
This is why there is no difference, if your air flow threw the head is max-ed out with the stock TB for sake of argument, then increasing TB size could not change the flow volume of air threw the head which was already max-ed out. If you ported the head to increase the max air volume flow then a after market TB could make more power.
Hope that helps.
Throttle body spacers. worth the money? MrRogers 1987 - 1996 F150 & Larger F-Series Trucks 7 01-02-2010 09:29 PM
'93 F350 7.5L Throttle Body issues KG32A 1987 - 1996 F150 & Larger F-Series Trucks 6 06-19-2009 08:50 AM
Broken throttle body mounting bolts jsimpson 1987 - 1996 F150 & Larger F-Series Trucks 6 01-18-2009 08:35 PM
Help. Coolant leaking from 5.0 1994 curbthrasher 1987 - 1996 F150 & Larger F-Series Trucks 0 12-16-2008 04:19 PM
Throttle body spacer - worth the money? mjunk1 Performance & General Engine Building 35 01-17-2006 02:30 PM
Tags
49l, body, size, throttle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
