Harpoon mod? - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Harpoon mod?
Old 03-25-2004, 02:37 PM
Jerrod Jerrod is offline
Jerrod is starting off with a positive reputation.
Harpoon mod?
I am looking for information on the harpoon modification so tank fills without nozzle kicking off. Have done a search with basically no luck. Any help would be appreciated.
Old 03-25-2004, 02:51 PM
jschira's Avatar
jschira jschira is offline
jschira is gaining momentum as a positive member of FTE.
The vent for the inlet filler tube to the tank has an extension that sticks down about 3"-4" from the top of the tank. When the fuel hits this extension, the vent is closed off, so the fuel going in the main filler tube has to flow against the air trying to come out of the filler tube. That is why the tank fills so slow for the last 4-5 gallons.
The Harpoon mod (named for "Maroon Harpoon" who first suggested this mod) involves dropping the tank and cutting off the vent pipe extentsion flush with the top of the tank. The vent pipe is just PVC, so you can cut it off clean with a PVC pipe cutter.
The mod is extremely easy and alsmost free. Dropping the tank and putting it back is the hard part.
Old 03-25-2004, 02:59 PM
yellow73bb yellow73bb is offline
yellow73bb is starting off with a positive reputation.
I just did this last Saturday on my 2000. What year is your truck? The later ones (current body style?) only need to have the pickup tube cut off. It's pretty simple. Older vehicles take a different mod. For mine, I took some tie down straps to hold the tank in place as I unbolted it. Then, I unbolted one end of each strap and lowered the tank down low enough to get the pump/fuel lines off. These are held on by a big "nut" like thing, that looks like a giant platic pipe threaded thingy (technical term ). I used a long screwdriver and hammer to turn that "nut" counterclockwise until I could turn it with my hand to remove it. Next, I removed the two tubes going to the fuel fill door, then lowered the tank on down. My pickup is a crew cab short box, I was able to rotate the front strap out of the way, and just bent the back strap. Once I got the tank on the ground, I reacned in with a ratcheting PVC pipe cutter and cut off the tube sticking down in from the small tube. Putting the tank back in the truck is pretty much the reverse of removal. You may find it easier to use a jack to hold the tank in place while you put in the screws.
It goes without saying, I hope, that you should have the tank pretty close to empty before doing this.
Before the mod, the tank would only take 22 gallons or so and then I had to dribble in the last 4-5 gallons. Now it takes 29 gallons before shutting off. I'm happy with it.
Old 03-27-2004, 09:44 PM
Yellow72bb
My truck is a 2000 crew cab. Thanks for the info. How about for fog lights? Did yours come with it or did you add them? What kit did you use for the lights if you added them?
Old 03-27-2004, 10:31 PM
No fog lights (yet). Not sure if I need them or care to have them.
Old 03-28-2004, 08:56 AM
spitball spitball is offline
spitball is starting off with a positive reputation.
I like the factory foglights also.. But went with after market and stuck them on in the same position...
Hutch n' harpoon Mod Worth It? microdevil45 1999 - 2003 7.3L Power Stroke Diesel 58 07-08-2016 12:56 PM
Harpoon The Tank? Choctaw Bob 6.0L Power Stroke Diesel 186 08-03-2015 04:24 PM
Harpoon Mod! beanhead6D5 6.7L Power Stroke Diesel 6 07-12-2015 01:10 AM
hutch and harpoon parts list rat49f6 1999 - 2003 7.3L Power Stroke Diesel 27 06-16-2009 08:03 AM
Fuel tank size with Harpoon mod? Lushman 1999 - 2003 7.3L Power Stroke Diesel 10 06-27-2006 07:56 PM
Tags
1999, 64, 73, 73l, diesel, dropping, f350, ford, fte, harpoon, liter, maroon, mod, tank, tube, vent
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
