Steering Box rebuild: sector shaft bushing installation help needed (59 F100)
Hi gents,
I'm rebuilding a steering box for my '59 F100. How do I get the two brass sector shaft bushings installed without wrecking them? Putting them on the sector shaft, then inserting the shaft into the box housing just bends them, even with the box heated. Putting them inside the box first doesn't work, as the splines on the sector shaft just push them out when the shaft is installed.
What am I doing wrong? Is it a job for a shop, or are there special tools? Or am I missing something obvious?
Here's a pic of the sector shaft so you know the part I'm talking about:
Thanks for any guidance you can give.
- Jay
- Jay
Hi Jay,
I've never done one of these myself, so I don't know if this will actually help.
STERING GEAR ASSEMBLY
1.) If a sector shaft needle bearing is used, install the bearing assembly in the sector shaft cover with tool T54L-6266-A.
2.) Install the sector shaft and adjusting screw in the cover, and install the lock nut loose.
3.) Install new sector shaft bushings in the steering gear housing with tool T57T-3576-A.
4.) install the worm shaft upper bearing cup in the housing with tool T57L-4616-A2.
5.) Position the worm shaft upper bearing on the worm, then install the worm shaft into the housing.
6.) Install the worm shaft lower bearing and cup.
7.)Install the housing end plate using the same thickness of gaskets as was removed.
8.) On F-, B-, or T-Series, Temporarily install the steering wheel and check the worm bearing preload with a spring scale.
Worm bearing pre-load (Pull to keep wheel moving - Lbs.) for F-100 & F-250 is 1/4 - 3/4.
9.) Install the steering shaft upper seal with tool T54L-6015-A.
10.) Install the sector shaft and cover assembly in the housing using a new gasket. Install the sector shaft seal with tool 77837. Lubricate the worm gear.
11.) With steering wheel temporarily installed, locate the high point and adjust and check the worm mesh.
12.) Remove the filler plug and fill the housing with specified lubricant.
Sorry, I don't know what these tools are that they refer to. I hope this helps anyway.
hi jay, i'm with kenny on this, my book tells me the same, having said that, if u have measured the new bushings and they are correct u may need to try heating the box/bush's while at the same time freezing the sector shaft ( wipe the excess ice of first, or wrap it in plastic before freezing) c how u go....cya...gary
tinman52
06-29-2016 09:56 PM
eb4strom
09-20-2014 08:26 PM
jjreagan
02-21-2014 04:30 AM
Tomget
07-28-2012 01:57 AM
57_ford
10-17-2005 08:56 AM
