03-28-2004, 04:40 PM
If you plan on running 40's on a TTB good luck with that, unless this truck is gonna be a mall wheeler. I would want nothing less than 1 ton axles under my truck with tires that large. You could get away with 37's on your stock rear and swapping in a D44 solid up front if you don't beat on it too much. I also reccomend, if you have the skills and the tools required to do a little fabricating to swap in a d44 from a 78/79 bronco. It already has long arms and is a bit stronger than the TTB.
