03-24-2004, 10:27 PM
It's not too difficult. There are several hoses and wires to remove. Make sure you keep the spreaders (wierd looking washers) in the same place as they come out and torque them to 36-60 in/lb. I start in the middle at 36 and work to the ends. Then do it again at 60. If you have the tools and a good place to work, you should be able to get them off in about 30 minutes. Plan a little longer to get them back on, and replace the gaskets.
