My plan is to run electric cooling fans on my balanced 302. The radiator in my truck measures 24" W x 18" D. All the fans at Summit or others aren't quite the same dimension. Is anybody running a fan that works? And if so, what kind and what are the dimensions? Thanks. Jim
If your cant find one from all the performance Cats? then try your Local auto parts shop!! And if they cant order you one
(Im sure the can) Just grap your tape measure and head to the bone yard!!!
Good Luck !!! Russ!!!
__________________
Blue Saphire 70 F250 390/C6 Limited Slip 4.10
Hedman Full length
Holley 750
B&M Mega shifter
Sunpro 5" Super Tach III
ION 138 series wheels
With a Secret BBF/TBA sometime??
im running two toyota front wheel drive fans on a home made bracket in front of my radiator with individual switches , works great in my tow truck,bob
thanks for the tips. I surfed into the Flex-a-Lite site, they have a new twin 13.5" unit, 28x17, new design w/thermostat and AC relay. It has an adjustable, variable speed switch, CFM's from 2600-4600. It's the one I'm looking for, I'll let you know the $.
That new fan is the model # 295, from Flex-a-lite.
It's a little bit larger than the core on your current radiator. If your radiator is still a stock down flow radiator, the fan can hang over the sides of the core, you just need to fabricate something, flat piece of metal, for the fan to seal against so it doesn't just suck the air in from the sides.
With the fan rated @ 4600 CFM, it won't have any problem keeping a 302 cool.
