Go Back   Ford Truck Enthusiasts Forums > Misc. > Cooling, Heating, Ventilation and A/C
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Click Here
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-24-2004, 03:00 PM
spdjunke is starting off with a positive reputation.
Noisy AC compressor.....
The AC compressor and/or clutch in my 91 Fullsize Bronco is making a grinding/squealing noise.
When the engine is running, AC in off position everything is fine...
When engine running, selector switch in ANY position except VENT or OFF, the noise happens...
I popped the hood, the compressor pulley is turning fine, but if I try to turn the inner plate on the clutch it is binding.
Any way to see if compressor is bad, or is it possible to just easily change the clutch on this? I checked the schraeder valve and there is still pressure in the system.....
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-25-2004, 08:10 PM
Ecuri is gaining momentum as a positive member of FTE.
Observe clutch while A/C is on, looking for slipping. Guages will tell you if the compressor is failing...unsteady pressures will be observed. I think you have the boxy York compressor? If so the clutch is easy to change... an impact is handy for dis-assembly... thread a 7/8? NC into the center to pull the clutch. GL
__________________
78 F150 408 4v valves/C6
77 F250 390/NP435
99 Explorer daily driver
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
